Not only that. They also have about 10% third harm distortion (30Hz to 60Hz) at 90dB SPL where DCA has as good as no distortion.
not really comparable. I own one and it really is only usable at background and 'normal' listening levels. Mine was lightly modded later on.
FR in all 4 settings where blue is setting 4
150Hz is +10dB this, at least to me, is bloated and unlistenable. (horizontal line is audible flat, Harman-ish correction applied.
Only setting 2 is good and 3 for popular rock and older recordings.
Same issue for the 1540, high 3rd harmonic and compression already starting at 90dB SPL in the bass which is not as good as one would hope.
It's a linearity thing it starts to 'compress' above 95dB SPL in the lows which isn't that loud (for low bass, it is for mids)
Below the linearity plot.
90dB
Also FR of the 1540 is way too bloated in the lows, not as bad as COP in setting 4 though.
150Hz = +7dB which is consistent with Oratory as he drops the EQ -7dB there.
These will sound bassy and bloated compared to DCA which will sound a tiny bit more bassy than neutral, not bloated at all.
With EQ the 1540 sounds quite good up to normal listening levels.
below SRH1540 vs Ether-C flow
The stealth only 'boosts' the 100Hz region by 2.5dB (the Ether C flow did this as well but had a small midrange bump as well and had a little less clarity but already showed good smooth treble response.
