audioBliss
Basically the only reason to used sealed subs is because you want to reach as low as the room allows. In my current room it's 7Hz before drop off. But as you might know sealed subs naturally roll off at 40Hz or whatever so they need to be boosted below that. Typically you might need to boost about 10dB to get it to above a flat line. Every 3dB costs twice the power. So if I have to boost 1.5dB just to get flat response from the amp it's pretty significant imo. But sure the subs probably don't need that much power for really low frequencies or they would break But still I like to remove as many variables as possible in the chain so that I know what is happening when calibrating or whatever. To me at least it seems that it would not be too hard for them to make the amps so good that you can just take them out of the equation so to say. It's hard enough getting excellent sound.
