What's the impedance like up to 100k+ range? If it appears to be inductive then the model is not really accurate.
I just want to know how many speakers are capacitive up to 100k+ to 10Mhz. As shown in previous graphs, the impedances are capacitive up to 20khz. What about the range that actually affects stability?You may make almost any impedance load you want and need to test. You just use same parts as for speaker crossovers - big coils, big MKT foil capacitors (like the one in post #1).
You may also use coils with non-linear core to simulate speaker's non-linear impedance partly.
Please stop excuses. There are designers who want their designs to be able to drive speakers including Martin Logans, without excuses for their "incompetent" impedance . BTW, Martin Logan speakers have very nice sound so you might consider ability to drive them - might be good even from business point of view .
Never said that. Never said it is the one and only that should be tested. However, it is one of the load types that any good amplifier should be able to drive.
No, they are very unusual.Martin Logan's are not unusual and they are not the only ones with similarly low HF impedance. .
So no stability issue then.None of the loads shown here are capacitive above 20kHz. Even the load in post #1 is inductive above 20kHz - as a result of both small R2 in series with C1 and load lead (inlet) wire inductance. And real speakers are also inductive above 20kHz.
Now it's just low impedance load in general. Being able to drive 2ohm load perfectly and 1ohm load safely is good enough. For special speakers just design special amps for them. No issue.
It's not capacitive after 20khz. So no phase shift to affect stability.Sorry, your assumption is wrong. Because resistive load 1,2,4 ohm or whatever has 0° phase angle of impedance and no imaginary component. You seem to share same misunderstanding of amplifiers stability with @amirm . The load in post #1 has capacitive impedance from 200Hz up to 20kHz and may result in amp instability, depending on amplifier loopgain amplitude and phase plots. Depending on C1 value as well. This is the routine for us analog circuit designers to investigate amplifier's loopgain plots and also response to voltage step with different loads and we know possible issues and how to cure them. It may not be so clear to those who just make an assembly from OEM modules designed and produced by other manufacturers.
OK, I went rummaging in my box of crazy crap and it turns out I had the parts to try this test so threw it together on the bench. Slight variation, 30uF and 0.56 ohms.
Purifi amp running 4 ohms resistive at 5 watts
Purifi reactive load
No issues at all.
Of course double blind tested, as I have known your requirements to others
Offensive to Amir and me in one post. Its disappointing you feel the need.Sorry, your assumption is wrong. Because resistive load 1,2,4 ohm or whatever has 0° phase angle of impedance and no imaginary component. You seem to share same misunderstanding of amplifiers stability with @amirm . The load in post #1 has capacitive impedance from 200Hz up to 20kHz and may result in amp instability, depending on amplifier loopgain amplitude and phase plots. Depending on C1 value as well. This is the routine for us analog circuit designers to investigate amplifier's loopgain plots and also response to voltage step with different loads and we know possible issues and how to cure them. It may not be so clear to those who just make an assembly from OEM modules designed and produced by other manufacturers.
It would still be interesting to see what you come up with if you have the timeSaved me the work.
