You keep saying these things, and they keep being untrue. The incorrectness of your statements is exceeded only by the certainty and frequency with which you are making them.
"Delta-sigma dacs/oversampling will only ever be useful as long as high res music is not played into it" - this is nonsense. As in, it literally makes no sense. DS DACs process higher sample rates and higher bit-depths just fine, and conversely a non-DS DAC (or an outboard upsampler like the Chord) does absolutely nothing to make "high-res" sources any better. The limitations of high-res digital sources in improving upon redbook are dictated by digital sampling theory and the range of human hearing, not by the type of DAC you run them through.
You say that you are using "(stairstep)" because "other people call them that." But they are not that. If you don't know that, then you misunderstand the basics of digital sampling theory and therefore of what allows this stuff to work at all.
If you do know that - and your last comment implies that you do - then you are not comprehending how this fact undercuts your argument here, as you have used the stairstep fallacy as the foundation (whether you know it or not, and whether you are willing to admit it or not) for your claims about "time resolution" being a problem that needs to be solved in DACs, and a problem that can somehow be solved in incremental, gradual ways.
RE a NOS DAC, you keep banging on about how such a device is not "broken" because an oversampler can be "added" to it. This is semantics - it's restricting the definition of "broken" until it's meaningless. If you have to augment a DAC's functionality by grabbing a digital signal out of your source in order to remedy a built-in deficiency in the DAC's design and performance, it is reasonable to call that design broken - "built-in deficiency" = "broken by design." And even more importantly, it is manifestly unreasonable to try to argue that it isn't. The only way out of that is to claim that NOS produces superior analogue output - which it most certainly does not. It's analogous to how any DAC that benefits from a "galvanic isolator" (and to my knowledge Amir has found only one, the Modi 2) is not "okay but can be taken to the next level" - rather, it is a broken design. It simply fails to do something basic that electrical, electronic, and/or digital data knowledge tell us can be done, and done fairly simply.
Now, when it comes to R2R vs Delta-Sigma, sure, R2R does not equal NOS - there are indeed oversampling R2R DACs. But that's not the point here at all.
Oh - and we still can't hear, detect, or sense 100kHz. That hasn't changed since your last incorrect comment. We'll keep monitoring the situation, though.
