Hey
@pozz, I agree with everything you say BUT
Since I agree with you, I would like to know if there are any personal recommendations on this sort of thing that you would suggest.
IMO the cheapest it gets is to DIY acoustic panels (even though it is somewhat expensive), what do you think?
Thanks.
Not sure if I posted this earlier on but the cheapest thing is probably reading the books. Besides understanding how the devices work, your hearing sharpens as you learn more about what's happening around you.
But this thread is more about the tweaky variety of things.
I guess solid stands for small speakers, if you have the room. Adjustable height is always good. Usually expensive, though.
Switch to balanced connections forever. Ground loops are a persistent problem and this will get you out of most of them.
Instead of buying mass market cables buy those from pro companies (usual suspects: Belden, Canare, Mogami). Ruggedness and dependability go a long way. Stick to IEC power cables. For any cable purchase, buy something reasonably longer than you need.
For me, the Brickwall/Zero Surge/SurgeX power distributers have proven their worth over the years. Power's gone out more than a few times and it's nice to know there's a well thought out buffer in between. Again, expensive.
Always consider level when planning your system. The lower the total system gain, the lower your noise floor. Helps with picking gear.
Keep your audio junk organized with velcro (for cables) and dedicated cases/boxes (other things). Bags for headphones suck, but a nice case goes a long way. Larger pro cases for electronics are good too.
I've not really found damping material for speakers useful. For turntables, some level of vibration control should be built into the unit. That said I do use foam under my (small) speakers. But as a kind of prophylactic. For towers I would expect good feet or a good base as part of the design.
Obligatory mention of EQ: figure out some way to get it into your system.
Obligatory mention of subs: a good low end is magic. However integration is nowhere close to easy and
requires a measurement mic and EQ.
For speakers, if you're considering buying acoustic treatment, consider buying better speakers instead. Don't underestimate the power of smooth directivity. Bad or highly variable vertical directivity makes for a difficult time listening. Great speakers alleviate a lot of problems.
If you do buy treatment, you might start hearing problems you didn't hear before. Especially muddy stuff happening at lower frequencies where the absorption loses effectiveness. So worth thinking systematically about the entire room, not just getting a few panels, and getting thick panels.
DIY is cheap in cost but expensive in skill and time. It's also pretty easy to DIY stuff but have only the most rudimentary idea of how it works, and give yourself the wrong impression of its effectiveness.
Between aesthetics and performance, choose performance. Usually it's fairly easy to get both right with some research.
I think that's about it. I guess most of that stuff isn't actually about making some audible impact, but rather setting up your buying decisions so that you don't have to tweak.
I apologize for the rambling style of the reply. I was thinking about how I've set up my system and stuff I've done over the years.
The advice will definitely push your spend upwards, but for good reason in my opinion.
