Dirac claims they are coming out with “active room treatments,” but I am here to tell you they are not the only option!
If you're like me and love cats almost as much as music, then using them as active sound absorbers in a desktop setup is a no-brainer. Not only do they look adorable lounging in front of your speakers, but they also provide a soft and snugly barrier that helps to tame the sound waves and absorb reflections. And while it's true that cats may not necessarily save you money over traditional sound-absorbing materials, they do also come with some unbeatable emotional perks not found in traditional treatments or DSP.
Of course, there are a few potential downsides to using cats as sound absorbers. Aside from varied musical tastes, you may need to keep a watchful eye on them to prevent them from pawing at your gear or rearranging nearby objects. And if your cats are particularly vocal, you might need to contend with a few meows and mews interrupting your listening experience. But let's be real - when you're using cats as sound absorbers, you're not just optimizing your audio, you're also adding a whole lot of joy and fun to your setup. And really, what's better than that?
Note: Cat’s hearing is a little more susceptible as humans with respect to dB levels and damage, so be sure remove your active absorbers (cats) and rely on the passive absorbers left behind (beds) when raising volume levels beyond casual.
