Cartridge alignment by electronic measurements.
Balle Clorin
I have not found a good way of aligning the cartridge Zenith/Horisontal Tracking angle by using electronic measurement and test records .
This article brings some hope , but I have tried similar tracks before with little success. I did not get a meaningful result then. The Analog Macic is too expensive for me , but I have ordered CBS STR-112 and have other IMD test records.
I did try to look at the distortion and Left/right phase difference at various radii across the records . But I do not se two null/ low distortion positions as theory tells me… I get one low point at outer edge and rising inwards..
How to you experts check and set Zenith /HTA electronically?
Maybe this thread could be a place to share electronic and measurement bases cartridge alignment methods.
PS I do have test record tracks for VTA and Azimuth, but please add your tricks too.
can be a basis for discussion even if nothing really new or original... (the 70s and 80s approaches totally democratized thanks to hardware and software)
(remains the approach of anti-skating which in fact will never be anything other than bias... can only be "wobbly"... this is the subject to be taken with the greatest precaution and where there have clearly been stupidities in fact...)
1. I tried this.. but maybe the issue gets complicated by the fact that the distance between the sinus peaks gets physically smaller in the inner grooves?
2. I also tried to compare the change in sinus zero crossing(stylus at peak =zero speed) but the crossing vary due different distortion on each channel, and rumble. filtering the 3150 hz tone used mad the phasee difference between channels shift!!. A loepass/highpass will gove a phase shift, but I only have one frequency+ harmonics, so why ....I am lost
Please add a better idea to measure Zenith/HTA...
take virtins in basic version or asio (you don't need the very expensive version with just the module to carry out w&f measurements, which is just analogmajik in very very reduced version, just few fonctions, smalls comments fir "help", and making the name disappear)
thd, imd , crosstalk, fr, etc
in real time ...
find discs with clean 1k, imd, 330hz white or sweep etc and you will have enough to make your measurements..
sound card with your park ( or only your park in asio?)..
rew can use to for somes mesureaments
hungaroton, ultimate, denon etc you already have everything in stock and much more... ;-)
virtins is very powerful software, just a little difficult to use.
Yes ,I got all those records, just need a correct method to interpret the result .
I can use CoolEditPro and REW for analysing.
It is just that the zenith search gives no good results that resemble the theoretical tracking error across the record
red and blue linen is what I get in phase,/angle difference
observe precisely the videos, the texts, analogmagik... you have everything in watermarks.. (see exploit the old texts which accompanied the adjustment discs from the 70s...) but you need software like virtins and a hardware means d acquisition.. ,-)
I don't really have any explanations for your case... just that starting with just a single frequency so high and coupled with a reduction in bandwidth is perhaps the way to explore? f*n
rew say what in realtime? h4 h5 h6 h7 etc? 48k or 96k?
what is important in many of these approaches is being able to work in realtime with thd imd etc... (except for fr or w&f) but be careful with the practices that have often been recommended to regulate antiskating... bullshit...
( for zenith ,measurements in imd rather low frequencies etc... virtins adapts to it automatically... I just need to know what part of the frequencies they have adopted at analogmajik.... special advice.... for you and your tests on your long track dedicated to w&f.... we can help you... make a precise adjustment of antiskating on this signal, at its level... therefore an optimized antiskating... )
That seems challenging. I visually align the cartridge to the protractor and place trust in the cartridge for decent accuracy. It would seem my standards are lower than yours. Hopefully, you will figure it out.
The stylus in not square with the cantilever. Cartridge needs-to be turned clockwise in the headshell
The tolerance producers have is plus minus 3-5 degrees depending on which angle. So 1 degree off is actually quite good. I have returned 60% of cartridges/Stylus bought the last year. The errors were 6-8degrees.
Here is a better picture
View attachment 358669The tolerance producers have is plus minus 3-5 degrees depending on which angle. So 1 degree off is actually quite good. I have returned 60% of cartridges/Stylus bought the last year. The errors were 6-8degrees.
You're making the case for spherical styli.
How's that for a bad stylus? Signet TK7LCa - I will not name names, yet... The OEM with the Boron cantilever was trashed, and is apparently rather hard to source.
Looks like typical cartridge /stylus quality to me…
I don't know, It was not an inexpensive replacement, I did get the cart with the broken stylus assembly rather cheap. Hoping to find the original - it is a rather nice cartridge. Shame, it's a nice line diamond, only skewed...
