boxerfan88
- Joined
- Oct 23, 2018
- Messages
- 419
- Likes
- 458
He said he found one…
Okay, then you have those that will alter the FR to create the audio anamorphic lens. See/hear these image to sound analogies just don't work very well.I’d say that the smoother the FR the more 4k it is
The answer to the question in the title is "no".
It sometimes is helpful to use analogies, but they often become incorrect beyond the simplest use.
4K and 1080 are specifically resolution/frequency characteristics. They have nothing to do with dynamic range, except that in modern TV systems you typically ALSO get HDR with 4K gear.Dynamic range has the same goal for both photography/displays as well as audio (recordings).
Show someone the difference between 1080p and 4k in the show room where you might be standing far away? Not a big deal. Show someone the super contrast of OLED blacks mini LED brightness, and people get excited. Screen size does matter (maybe SPL is a good comparison)
That's true. The problem is that displays have always been extremely poor compared to reality in terms of dynamic range and colour gamut. Whereas, most of us never experience music at home which has the quietest bits at -90 and the loudest at 0.Dynamic range has the same goal for both photography/displays as well as audio (recordings).
What are those 4 plastic transparent "things" ?
Some sort of diffuser?
And are they 8D as well? That's the new YouTube hype...My speakers are 8K...
JSmith
They are for adding "transparency", obviously.
