I just r
eviewed the 6-channel Buckeye Hypex class D amplifier. This is a follow up teardown to that review.
The amplifier is an assembly affair as all active electronics are contained in the Hypex NC252MP stereo class D amplifiers with integrated switching power supplies:
So the main job is routing the wiring to each module and input/output terminals. I was pleasantly surprised by the quality of the construction. While I will comment on some areas of improvement, they are really minor.
AC power input is from top right through the fuse and routed using the twisted read and white wires. While this coloring scheme is consistent with DC wiring, it should not be used for AC wires. Otherwise someone working on them may confuse them with DC low voltage wires with catastrophic consequences. The convention when AC and DC circuits are present in the same device as is the case here, is to use black or brown for "hot" and white or blue for neutral. The grounding terminal likewise uses a black wire and should instead use solid green or green and yellow wire:
I was pleased to see that the anodization was sanded off where the screw terminal is for safety ground. An ordinary washer is used. For belts and suspenders purpose, it is better to use a barbed washer that has "teeth" that really dig into the metal.
Plastic double sided taped clamps hold the wires (e.g. mains). These come loose over time and should be avoided. There are screws near all the wires so I suggest using a screwed in clamp. That said, I can't see anything bad happening if they come loose as they are not going to touch any sharp/hot metal.
Throughout the unit I found fine aluminum shavings/bits. Many were tiny but some were large enough to dislodge and cause a short in the fine pitch surface mount PC boards. You can see the specs in my larger shot above on the right near the speaker/XLR terminals.
Speaking of those terminals, they are all screw mounted which rules out me critiquing the soldering job.
All were tight and tidy:
Using adhesive lined shrink tube is a very nice touch and above norm for such builds or even commercial ones. The adhesive keeps air out and should keep the tubing in place past my lifetime probably.
Zooming in a bit into Hypex modules we see the same practice of using second or third tier electrolytic capacitors:
There are large vents on top that should keep the ambient temps low inside the unit and help with longevity of the unit. Note however that the main source of heat are hidden power transistors that couple to the bottom of the chassis. Don't put the amplifier on top of any other heat generating component. I can't tell if there are heatsink compounds between the amps and the bottom plate. If not, some should be there.
I usually expect the worst when an audiophile decides to build such amplifiers before the teardown. I was super happy to see that some of the best safety and signal integrity rules have been followed here leaving me with some minor nits. While the overall unit has no safety or regulatory certification (although the modules are likely such rated), I personally would not be concerned about using this amplifier in my own system.
Any
donations are much appreciated using
: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
