If it gets here and sounds good I'm happy. Not sure why last payment was billed only to wait another two weeks to ship, but if buyers waiting the longest get priority in the build/shipping process that would be helpful.
When clipping, the LED will change to Orange. The duration and "blinking" would be dependent on the clipping (if it is a continuous clip, LED would stay lit orange...but it is transient events it would appear blinking).@Buckeye Amps can you explain how the clipping and error indicators work? I assume to indicate clipping the light flashes when it clips and to indicate an error it flashes a certain number of times at startup based on whatever the error condition is. Is this correct?
I do not use Neurochrome buffer boards, noHi,
so do Purifi-based amps Coe with NEUROCHROME input buffers?
Buckeye Purifi arrived. I tested it with a pair of Sierra Towers by removing a Buckeye NC502MP amp that was there before and inserted the Purifi. To be honest, the difference in sound is minor. I imagine the Purifi is slightly crisper but I don't have any proof and I would be totally happy using either amp. Which brings me to an interesting point. Why buy a Purifi if you already have the NC502MP? For most people there really is no audible reason but other features may be of interest?
1. NC502MP is narrow. It's only 7.25" wide while Purifi is 10.1". That doesn't seem like a lot but the slimmer build is nice.
2. The Purifi uses 14.5W and NC502MP 23W while idle and while playing music at 75dB. (Kill-a-Watt test)
3. The Purifi stays amazingly cool after an hour running while the NC502MP is definitely warm to the touch.
4. Purifi has auto off/on option. I measured a 5 second delay to turn on and 10 min. 50 sec to turn off after no source.
5. Purifi sends a quiet snap to speakers when turning off with Auto On/Off.
6. NC502MP weighs 5.5 pounds while Purifi is 6 pounds 2.2 ounces.
7. Not sure I like the toggle switches for Purifi gain option. They stick out of back which could lead to accidental changes? Not an issue for most. My guess is they don't change settings without a power down?
Bottom line, with Purifi you give up the narrow NC502MP foot print for better energy efficiency and heat management. Audible difference will be subjective and difficult to conclude.
Does the Purifi auto-wake from it's sleep state with an audio signal?
Purifi 1ET400A specs: There is probably an error with the 2ohm output...Our brand new mono, 2ch, and 3ch Purifi amplifiers are now available!
- 425w @ 4ohm
- 225w @ 2ohm
Purifi 1ET7040SA specs:
- 750w @ 2ohm
- 400w @ 4ohm
- 200w @ 8ohm
Custom Input Buffer Board w/:
- Neutrik XLR connectors
- OPA1612 Input Stage
- TI TPS7A49/30 Voltage Regulators
- Clipping Indication
- Error Indication
- Soft-start
- Low, Med, High Gain settings
- Auto On/Off (along with Always On and 12v options)
Gain settings:
4ohm - 25.5dB/2.17Vrms (High), 20.5dB/3.89Vrms (Medium), 15.5dB/6.93Vrms (Low)
8ohm - 25.5dB/2.24Vrms (High), 20.5dB/4.02Vrms (Medium), 15.5dB/7.16Vrms (Low)
Mono Amplifier:
(1) Purifi 1ET400A OR 1ET7040SA module
(1) Hypex SMPS1200A400
7"x11"x3" Aluminum chassis
Neutrik XLR inputs
Standard 5-way Binding Post outputs
$779 (1ET400A)
$949 (1ET7040SA)
2ch Amplifier:
(2) Purifi 1ET400A modules
10"x12"x3.5" Aluminum chassis
Neutrik XLR inputs
$1189
3ch Amplifier:
(3) Purifi 1ET400A modules
12"x12"x3.5" Aluminum chassis
Neutrik XLR inputs
$1699
*speakON upgrade available for $50
*Rackmount case upgrade available for $150
*Free US Shipping
*International shipping available
Finally, the official Buckeye Amps Website!
Good catch, thank you!Purifi 1ET400A specs: There is probably an error with the 2ohm output...
We have a similar set-up. RZ50>Buckeye 3 ch Purifi>F208's. It is a discernible difference between the RZ50 amps vs the Buckeye Purifi especially at high volumes w/ HT. Can't recommend this combo highly enough.Earlier this week I received my 3 channel Purifi Buckeye amp. I’ve got to say, the improvement is much more than I was expecting. I am using it to power my LCR LS50 Meta speakers with the Buckeye amp taking over amp duties from an Onkyo TX-RZ50 (which I realize isn’t the best amp to begin with). I was already impressed with the Metas when using the AVR to power them, but upgrading to this amp really showed me how much the speakers can benefit from a lot of clean power. I get more fullness and clarity that I didn’t know was possible from just swapping out amplifiers.
I also have to give props to @Buckeye Amps for great support. I had a grounding issue upon installing my amp (constant 60hz buzz out of all speakers, including ones not powered via the Buckeye), and he was nice enough to help me figure out the best way to ground my AVR to the Buckeye amp. Problem solved now, and I can go on enjoying this wonderful amplifier
I’m pretty sure new NC502s have auto on/off, now.Buckeye Purifi arrived. I tested it with a pair of Sierra Towers by removing a Buckeye NC502MP amp that was there before and inserted the Purifi. To be honest, the difference in sound is minor. I imagine the Purifi is slightly crisper but I don't have any proof and I would be totally happy using either amp. Which brings me to an interesting point. Why buy a Purifi if you already have the NC502MP? For most people there really is no audible reason but other features may be of interest?
