Buckeye 3 Channel Purifi Amplifier Review (2nd)
Rate this Multichannel Amplifier
    Votes: 4 1.3%
    Votes: 6 2.0%
    Votes: 25 8.2%
    Votes: 269 88.5%
I got 2ch version of the exact same power amp from Buckeye based on Purifi Eigentakt modules. Using it in high gain setting, in a biamping config - Buckeye is driving tweeter and midrange, while Audiophonics nCore nc502mp based 2ch power amp is used for bass drivers. The two amps are working perfectly effortlessly and flawlessly together, and sound is always pure and relaxed, regardless of the volume settings. Never had so much (virtually unlimited) of the cleanest power available lol and speakers simply love it
Preamp is Benchmark LA4
DAC is SMSL SU-9n
@Buckeye Amps Everything is still going great! One feedback I do have is the indicator LED is bright enough to cast shadows on the other side of the room. Indicator LED brightness is a personal pet peeve of mine and there's probably others that prefer the opposite. Overall great job!
DAC is SMSL SU-9n
I see lots of room to add more stuff!
It won’t be the 0.5W as the Hypex SMPS will be on standby mode and not off it using Auto or 12v.
One change we hope to make late this year is better control of the SMPS to further bring down idle/standby wattage
PC power supplies have this feature, with only a low current 5 V (or 12 V? It's a while since I looked) permanently on to provide power for the remote power switch that turns on the rest of the power supply. So it shouldn't be too difficult to have this feature added to a commercial audio power supply.
A few follow-up questions:
Will the new Micro Audio 2kW SMPS also be used with the Purifi 3-channel design?
Re: the change you’re making for improved standby and idle, are those improvements related to this new SMPS?
The SMPS1200A400 has an SMPS standby pin on J5, appears it isn’t in use. If correct, wondering why? Guessing it would require another circuit for control/timing. Seems it could potentially solve the Auto/12V standby power consumption issue.
The 2kW will not be for the 3ch Purifi. But there is another version from Micro Audio that will be used.
This is a second review of the Buckeye 3-Channel Purifi based balanced class D amplifier. First sample had an issue with its binding posts increasing distortion. It costs US US $1,595.
Typical of Buckeye amplifiers, focus on what is inside rather the case which is utilitarian. An indicator nicely shows status of the amplifier (on, fault or overload). Back panel sports a 3-way switch for setting the gain which is very nice to have:
Let's get right into the measurements to see if the issue with distortion is resolved (I ran full suite of tests).
Buckeye Purifi 3 Channel Amplifier Measurements
Let's start with our low gain dashboard:
Looking at the spectrum of the FFT we see a large reduction in harmonic distortion compared to the first sample. SINAD as a result improves a bit although it is mostly noise limited. Still, we match the reference design, landing the amp solidly in our top 20 best amplifiers ever measured (out of over 200):
You need pro type interface to drive the low gain to full power (as much as 7 volts for 4 ohm). Fortunately high gain hardly brings any penalty:
Request was made to show power with reactive loads as opposed to just resistive as is the norm in my reviews (and industry). Using my new PowerCube loadbox, I can do that:
Capacitive load doesn't change things but inductive loads it down a bit more. SINAD remains more or less the same so really, nothing of worry.
SNR is the same as before and excellent:
Frequency response is flat as always: (should say "NO load impedance dependency"
Oh, forgot to mention that I am testing channels 1 and 3. Due to larger distance, crosstalk is even better now (and was incredible before):
Multitone shows an improvement of 2 bits:
Let's dig into power measurement where we saw the rising distortion before:
Performance is far improved. No longer do we have a large hump in mid-power region. There is a small increase that exists but we can ignore it:
Power remains as before:
Here is the warm up behavior:
I didn't re-run the on/off pop test. Should be the same as before (which was very good).
Reactive Load Amplifier Power Testing
Let's use our fancy Powercube loadbox to simulate both capacitive and inductive loads ranging from 8 down to 2 ohms (amplifier goes into protection with 1 ohm):
(ignore the color differences.) Response is perfect. Regardless of load impedance down to 2 ohm reactive, the amplifier maintains the same output voltage. Can't ask for more.
It is great to see such responsive companies such as Buckeye that take the results of a review and instantly jump on the issue identified to resolve it. And resolve they have. Performance is essentially identical to Purifi reference design. Value added is provided in the form of a 3-gain buffer stage and powerful power supply that allows all three channels to produce near full power when driven simultaneously. Results is one of the cleanest/most transparent multichannel amplifiers you can buy.
I am happy to add the Buckeye Purifi 3-Channel amplifier to my recommended list.
Got 2-ch version of the same from Dylan ... love it so far, no brainer
Paired it (in hi-gain mode of course), for bi-amping, with Audiophonic's nCore based NC502MP 2-ch power amp (Audiophonics is used just for the bass drivers) ... virtually unlimited power reserve per channel, brutal transparency, relaxed sounding at virtually any sound level ... room induced distortion is the only limit for me now ... what else to ask of a pair of more than affordable modern, high-efficiency class D amplifiers? And I am 20yrs Quad 909 sound fan ... which I still own, but not using it at the moment, as it is getting too hot in the summer lol.
Yes, Purifi is a newer, more advanced design than the original NCore. There's also the next generation Hypex NCoreX / Nilai that should be an improvement over the original NCore. That being said the NCores are still very very good and at this point it's more of 'how far can we perfect it' than actual audible improvements.
Agree ... however, those SINAD / THD+N differences are mainly demonstrated on a high quality test bench, like Amir's. In real life listening, from my personal experience, both sound very good and non-different, to 99.99% of audio lovers ... I have power amps, based on both of them. Just make sure you have high quality pre-amp and DAC upstream
Power consumption for the new 2KW & the new 1500W SMPS is less than 0.5W in standby mode.
Standby mode means your amplifier is fully off, and the ON / OFF control is done via the low-current standby switch.
A custom control port will be available for Buckeye to control the SMPS.
Hope that helps
Hope that helps
Thanks MA, this is good to read. I assume/hope the custom control port will be toggled by the external 12V trigger on the Buckeye side of the design.
DAC is SMSL SU-9n
I always wondered how these multichannel amps work with the tweeter. The hypex fusion amps had the nice option of 100 w channel. Eigentakt 250w< what will it do to a tweeter performance wise? Is’nt it totally overkill to use all those watts and dollars for the tweeter?
Not sure what you are getting at, please further explain. Since most speakers have two, three, or more drivers which produce sound.
Generally speaking a person wouldn’t buy a three channel amp and use it as a mono block
I assume @emilkoz is thinking about driving the speaker actively, with a separate amp/channel for each driver - and wondering if 250W for just the tweeter wouldn't be overkill.
Sorry and yes as Julf guessed, I'm in the active camp :).
Yes exactly ... my Buckeye Purify based 2-ch power amp drives Neat Acoustics Motive 1 speaker's tweeter + midrange drivers, while nCore nc502mp based 2-ch power amp is driving bass drivers ... no issues with tweeters at all
At my listening levels I am definitely wasting watts (probably using a minuscule fraction of available wattage per channel) but I don't care ... I could easily go with one of these amps and not bi-amp my speakers ... but now I have virtually unlimited power available per channel, giving me effortless pure sound and that's what matters to me ... these nCore and Purify based power amps are so cheap compared to class A / AB power amps that can measure similarly and that have similar wattage per channel (they are 10x heavier too)
