- Joined
- Jan 28, 2017
- Messages
- 635
- Likes
- 806
So I was considering the pros and cons of large vs small subwoofers. Clearly if you need to reproduce 10hz at 100+ db you need a large driver, something from JTR, Funk etc.
But what if you're producing 20 hz at 90db? Does a large driver, say 18" sound different than a small driver, say 12" assuming equal spl and distortion? The frequency range of the cello and double bass overlap, so do they sound the same when producing the same frequency at the same volume?
I don't know, but if the large and the small driver are both moving the same quantity of air at the same frequency they should sound the same. The smaller driver just has to make a larger excursion with each cycle. Would enjoy hearing thoughts of others.
