Best small passive speaker for scientific setup
Alt93
Hello,
I am studying sound engineering and currently doing research on 3D audio. At the university we have a wonderful audio dome based on Genelec One's for this purpose. However, it is often occupied or only available in small time slots. I have a decent room at home and would like to build a small 3D setup myself for my work. For starters, it should be a classic 7.1.4 setup. For this I need affordable, small, passive speakers in the best possible quality. I know DSP very well, so corrections in the frequency range are no problem. Everything that can not be influenced with DSP, such as radiation pattern, resonances, etc. should be technically as good as possible.
Do you have any practical recommendations for me?
Many thanks already!
Mal
What do you mean by affordable? For some $50 is affordable, for others $50 000...
As you are a student, I'll assume $50 - Wharfedale Diamond 9.0 are small and cheap. I have a pair I use as computers speakers, but don't have the techie know how to give you detail on radiation patterns and resonances! They have been around a long time (decades...) so maybe do a Google search to see if anyone has used them in experiments like yours. They have a fairly good reputation and seem solidly built, I can't say more than that...
Amir did some serious measurements on the Wharfedale Diamond 12.1s that might give a feel for Wharfedale in general... they are more than $50, though...
A
Alt93
Thank you for the suggestion.
My bad, let’s define affordable speaker for a large setup to something between 50 and 150$ each.
Elitzur–Vaidman
Are you comfortable with some basic DIY? The Parts Express C-Note earned a favorable review from amirm and cost only ~$50 each.
A
Alt93
DIY is fine. But reading the measurements it seams to have some build related issues.
Mal
In glancing at the manual for my Wharfedale Diamond 9.0s, I was amazed at the number of "surround" options that were made available in the "9" series:
Josq
Hello,
Any special reason why it needs to be passive? Adam T5V are excellent actives, no amplifiers needed
Elitzur–Vaidman
Looks good! Thank you! And I forgot to mention that coax speakers are appreciated!
Any other models?
I don't think you'll be able to beat KEF Q150s given your price constraints unless you happen to find a good value DIY coax (I don't know any).
Mal
Any other models?
The KEF Q100 had a mixed review, but you might find it in your price range second hand. Maybe contact KEF directly? They have a "send them your old kef and they give you 25% off the new kef" deal. Who knows? They might have a stock of old UNI-Q speakers and might be willing to sell them at rock bottom to a research student... worth asking them anyway...
https://www.audiosciencereview.com/forum/index.php?threads/kef-q100-speaker-review.11987/
The KEF LSX reviewed better. I have this as my main home speaker and I love it! You *might* find a pair heavily discounted/second hand for $600 if lucky... but it's not passive.
voodooless
Netherlands
What about Kali LP6 2nd wave?
Mal
Would the latest generation of bluetooth speakers have sufficient quality/capability?
I was amazed at the improvements in sound of the Amazon Echo (4th gen). I have one in my kitchen and I don't find it too painful going from KEF LSX to Echo when listening to talk radio and light music.
Thread here where people are discussing setting up 5.1 etc. Echo based home theatre solutions:
Elitzur–Vaidman
If you're willing to consider active, I can endorse the JBL 306Ps (or 305Ps if weight is a big concern).
mkt
I am curious whether you plan to use an AVR or not. An audio interface with enough outputs would be fine with active speakers.
sarumbear
Any other models?
Q150 is the cheapest co-ax speaker around that I know. If you can EQ them, the results in a 3D system will be similar to the Genelec system but at lower SPL capacity.
TonyJZX
the OP wants a 7.1.4 setup??? I wouldnt build anything and that gets old soon.
What OP needs to do is the keep an eye out for clearance items.
Harman are famous for this.
OP can get away with say 5" woofers if he relies on subs.
Rednaxela
NL
Do they have to be full range?
Otherwise perhaps have a look at KEF KHT-3005 or KHT-3005SE. You may be able to pick up a set or two for not too much.
