Behringer A800 Stereo Amplifier Review
staticV3
Just wondering if the A800 will have sufficient power for Revel F35's?
Here's what I got:
86.5dB/1W/1m is the F35's worst-case efficiency at 200Hz.
310W is the A800's burst power at 1% THD+N into a 4Ω, which is close enough to the F35's impedance at bass frequencies.
You can modify the listening distance and speaker placement here: http://www.hometheaterengineering.com/splcalculator.html
I just assumed 6ft distance and near a wall.
Pulkass
OK the joke's on ME!
I love that. Great test. Thanks for sharing.
Reminds me of a photo from an audio society meet, of a bunch of audiophiles sitting in chairs, straining to hear the difference between two CD playback setups in a single blind test between an expensive Mark Levinson or some such expensive setup and the other with a cheap JVC DVD player into an Alesis power amp (similar idea to the Behringer power amps). The speakers were the same for both, only the electronics differed. Despite their intense concentration, the audiophiles could not reliably tell which was which. I wish I could find that photo, it's priceless.
Interesting that the only audibly different amp was that little Tripath amp, and only when called upon to drive 4 ohm speakers to loud levels. Of course you can tell the difference, it had to be running at like 5% THD or something.
Anyhow, I guess I'm talking myself into hearing differences between the Hafler P1000 and the A800, or perhaps the Hafler has gotten old enough that it's in need of restoration (probably needs power supply capacitors replaced, as they are roughly 25 years old).
Good stuff.
But why Spotify? They are compressed MP3 files. Better to use Qobuz hi Res files. !!!
D
Deleted member 48726
Guest
No they are not.
I bet you can't tell any difference between lossless and Spotify. Try the tests in my signature. Looking forward to hear your results.
Pulkass
No they are not.
I have a hi resolution system. I can hear the difference. No need for a blind test.
gasolin75
Denmark
Just wondering if the A800 will have sufficient power for Revel F35's? According to Amir, the F35 falls to 3.5 Ohms (I think around 200 Hz with sharp phase rise before). I believe the A800 does around 200 watts at 4 ohms, so it's probably going to have more than enough at 3.5 ohms? I'm already an A800 owner
check you data you wrong (do you need 500 watt to play loud enough with a pair of revel F35 ?)
2023-12-26 13_13_50-Behringer A800 Stereo Amplifier Review _ Audio Science Review (ASR) Forum ...png
