Yorkshire Mouth
Another school day for me.
I've just been watching one of Erin's typically great videos, this one being on the JBL 4329P.
In the video he says the speaker measures on the spinorama as going down to 30hz, but when you put in your room it'll go down to 20hz, dependent on the room.
Now I've heard this sort of thing before. Obviously, before anyone points it out, I know all rooms will be different, but I have a few questions.
1 - Whilst the amount may differ, will pretty much all rooms make a speaker go lower?
2 - Is room size the the dominant factor? As a general rule of thumb, will a larger room take it down lower and a smaller room less so, or the other way around?
3 - If you have your room treated (bass traps in corners, etc.), will this negate the effect, or does this deal with a completely different issue?
4 - Is the effect dependent in any way on the speaker, or is this purely how the room operates? In other words, if you put two different speakers, both going down to 30hz in the same room (at different times), and the room takes one of them down to 20hz, will the other speaker also go down to 20hz, or will the room always affect LF in the same way; is it completely room dependent?
Many thanks.
Many thanks.
