https://audioxpress.com/article/patent-review-loudspeaker-with-a-wave-guide
Finally a pretty good explanation of how the slot loading provides increased LF directivity. I quote the relevant passage:
To extend vertical directivity, as disclosed in the patent (and the Genelec datasheet), the Genelec system adds an oval 215-mm by 100-mm woofer at each of the top and bottom ends of the enclosure, with the output of each of those woofers exiting out of a small (approximately 13 mm) slot running the width of the cabinet. This provides an additional pair of acoustic output sources at each end of the enclosure with a center-to-center separation of approximately 432 mm (17”). The woofers come in and extend down in frequency from 500 Hz to the lower limit of the system (claimed –6 dB at 32 Hz).
Besides providing the system’s low-frequency capability, the two slots interact with the waveguide over about half-octave, and then operate independently to maintain substantially constant directivity down to about 280 Hz. This type of spaced, dual source aperture can result in a simple and efficient means to enhanced directivity control. While a well-designed waveguide may maintain directivity down to about one-wavelength of its largest dimension, and a woofer, of the same active source diameter, can substantially match the directivity of a waveguide of the same dimension, a dual-point source, or slot source, can maintain the same level of directivity control to a frequency approximately 1-octave lower. At a plus-and-minus 90° angle from the zero-axis, a dual source will exhibit a cancellation null in the response at the frequency of which the center-to-center spacing is 0.5-wavelength, while exhibiting greater directivity between the 0.5-wavelength and one-wavelength frequency than a single source of the same dimension. So, in a small package that would normally only sustain directivity to a frequency at least an octave higher, this system can maintain very good constant directivity to a lower frequency, in one plane.
Really liking this "Patent review" serie, personally.
