Audiophonics DA-S250NC DAC & Power Amp Review
Rate this Amplifier and DAC:
    Votes: 6 2.3%
    Votes: 20 7.6%
    Votes: 170 64.4%
    Votes: 68 25.8%
DTTOM37
French side of Europe
Nor me. All our music, apart from one album which I got from Apple Music because I couldn't find it on CD, is ripped from CD, bought new or used. We can stream it anywhere in the house, and because it's also on iPhone, can be listened to on foot or in the car, with no mobile data usage.
Looks (y)our habits are a bit "outdated" for most generations that came after you/us. ;-)
Personally, I tend to agree that streaming from a local source is my favourite, given that when I was 20 I had already about 300 vinyl records in my library and almost the same numbers of C90s - and I would describe myself as a music enthusiast (kind of dis-horder-ly) who don't want to loose access to the sources of pleasure. Most sources from the last 45 years are still accessible for me. ;-)
I do use Qobuz, but mostly for discovery, I often buy from them particular downloads, while my preferred sources are still Bandcamp for DL or Discogs for CDs I would rip myself.
My suggestion for the USB device on the router was primarily for easy going functionality testing, I was aware that Nicolas had mentioned his own NAS. I own a fully equipped UNRAID NAS (24 TB) myself, however, I use it only in the winter half, as I am in need for using an audio PC (low powered) anyway for my active speaker system. Therefore, a SSD attached to it seems to a more economic/ecologic solution to me.
AudioSceptic
Northampton, UK
Yes, and I'm not ashamed to be outdated. Why should I buy a download when I can get the CD for less money, inc. delivery, which also gives me the ultimate backup? Heck, I can even *play* the CD on some strange machine (weird, I know, but not as weird as another strange machine that spins huge vinyl discs with grooves cut into them, dragging those grooves against a tiny rock which somehow gets music out of them). :)
Steph75
Hello,
I am quite interested in this amp (the wifi version). It would be associated with Dali Opticon 6 in order to withdraw a Marrantz 6005
My sources are only numerical (TV, Airplay, Upnp… from Synology, IOS, ITunes, RPI…).
What are the direct challengers of this amp, if possible with ethernet input or/and with the more powerful Hypex NC500
Does someone know if it is Airplay 2 compatible?
DTTOM37
Hello,
Hi Steph,
this thread is about the Amp/DAC combination called DA-250 NC, not about the Amp/DAC/Streamer called DAW-250 NC. About the latter (DAW) you find reviews elsewhere.
The DA device does not support wired or wireless protocols beside Bluetooth, however it does offers toslink/coax/USB as digital inputs
In my opinion - if fully digital - you may be better off with a combination of Amplifier (Audiophonics) and Streamer/DAC (i.e. WIIM Pro plus) or perhaps a streamer that provides you with HDMI ARC, where the latter two could be the device you change/keep according to your (not) changing demands on digital media.
Reasoning:
- For one, the WIIM device seems to be under permanent development in order to add features and fix bugs.
- Secondly, streaming and DAC devices are markets where the next best thing is still to come, even it may not be the "best" for you (i.e. WIIM Ultra ?),
- while the budget amplifier market seems to be matured and clear (to me) in favor of TI 325X or Hypex nCore 12x/25x boards.
- Your RPI can have almost the same functionality as the WIIM devices, but you may lack the readymade and intuitive GUI/APP with Multiroom etc. and it may cost you hours on the RPI configuaration to get close to the WIIM experience, depending on your knowledge and leaning curve.
If your speakers aren't that demanding wrt power output, you may like to compare the WIIM amp as an AIO option, too ?
Steph75
Thank you very much DTTOM37 for your prompt response.
I will follow your advice and go on with the DA-250NC (I will be then in the right thread ;-) ).
Rergarding the WIIM Pro plus, is there any advantage when attached to the DA-250NC compared to the Wiim Pro (non-plus)?
The only difference between the two seems to be the Hi Rez DAC of the analog output? This Hi Rez dac would then be have no use with the DA-250NC since it does not have any analog input.
I plan to use Hi Rez music, I understand that those would be decoded by the amp, even if they go through the Wiim Pro, am i correct or am i missing something?
Mulder
Gothenburg, Sweden
Om
No. Pro Plus make no sense if you are going to use it’s digital output only.
DTTOM37
agree with Mulder ...
Info: It its the DAC board in the DA-250 NC thats converts the signal. If you are only onto a digital in/out (transport) for your signals, you may:
- use toslink for TV
- use coax for ?
- Use USB for your RPI as streamer serving you with DLNA/UPNP/AIRPLAY/NAS connectivity via Ethernet /WiFi
- you can use your RPI with a digi board on top to gain more input connectivity- and connect it via USB to the DAC input of the DA-250
- If you go for the WIIM pro plus, you may have the better DAC on board and you won't need an amp / DAC combination, but only a power amp if you are fine with digital volume control inside the WIIM device (remote control available)
- if you won't use the DAC of the WIIM you may manage with either the WIIM mini or the WIIM pro as a digital transport only, providing network access for NAS, UPNP , DLNA, Airplay 2 - this provides the same GUI for you.
I may have read that the advantage of the DA-250 is the point that the DAC doesn't drive the amp into clipping (please correct me if my memory dosen't serve me correctly !), which could otherwise happen unfortunately with the NC25x power amps in specific combinations.
If members use the WIIM Pro plus with a power amp combo, they may want to report here for guidance.
Cheers, Tom
edit: The DA and the DAW device are looking for owners that want an easy-to-go solution called AIO (All-in-One).
For the (imho) interesting price you'll get a nice design, good amplification, a mediocre DAC (which is good enough for most) and for the DAW as well a Linkplay module produced for third parties and integrators. In general you may do better with separates, but you'll lack the easy-to-go / good enough charisma with that. It all depends on your personal goals. If you are looking for a an external streamer besides the RPI, you may want to rethink your initial choice and find a device with analog inputs that serves your needs.
First step(h): define the importance of your different digital needs: toslink, HDMI arc, WiFi, BT, Ethernet, DLNA, UPNP, NFS, SMB, CIFS, Airplay 2 and select your future devices accordingly.
Bleib
Sweden
Something new:
GiBo61
Mulder
Gothenburg, Sweden
DTTOM37
You can connect a DACs analogue output to either the XLR or RCA inputs of this amp.
Excuse me for asking, I was afraid, that - sans clarification - some may think this model may have the same core functionality like the one from the original post - which has a DAC included.
Even for me (and I assume you, too) it is clear that it hasn't, that's not obvious for everyone from what I have experienced throughout the years in audio fora.
I would think, the main similarity of both amps is the Hypex NC 252 amplification and the manufacturer. The chassis, too.
Its basically a DA-250 NC without digital entry but multi analog inputs, called P-250 NC
DTTOM37
Which in my reading makes the DAC another analog source to the amplifier.
Pls excuse my perceptual nitpicking, It is for the "hopefully" correct understandig of other readers.
Mulder
Gothenburg, Sweden
My point, which perhaps I shouldn't have assumed was implied, is that a preamp is really only needed if you have analogue sources such as a record player, reel-to-reel or perhaps a cassette deck. If you have a digital source, and therefore a DAC (or CD/DVD/BLUE-RAY-player), as your only source, this can usually be connected directly to an power-amplifier. A separate pre-step is not required. This AP310-P250NC Integrated Amplifier from Audiophonics therefore, in my opinion, does not fulfill a meaningful function if you only use digital sources. But if you have analog sources in parallel, for example a record player (and a phono stage), it is super. A really good all-in-one solution. (Then you could also get a simple and less expensive DAC without Volume-control)
Verig
No, cd-players, dacs, riaa's, tape, are never meant to be connected to a power amp. Trying to omit preamp is just weird. Also, what does "analog in parallel" mean? A TT always needs a preamp of its own. Modern dacs can be connected directly if you're brave enough.
Mulder
Gothenburg, Sweden
I have had my RME ADI-2 DAC connected directly to my power amp for several years now. I also have a Topping which I also connect directly to a power amp. You say I can’t. I say I can.
Analog in parallell with digital - that is what I mean. Digital and analog in the same system. Of course a TT do not need a pre-amp of it’s own, if you with a pre-amp don’t mean a phono-stage. You can connect it to the same pre-amp as your digital gear. That is what I meant with parallel.
Curdrone
Hello,
I was planning to buy an Audiophonics amplifier from the DA series. However, I read in a customer review on their website that the display produces a high-frequency sound when active, which, according to Audiophonics, is normal.
As I am extremely hypersensitive to such things, my alarm bells rang immediately.
Can owners of these devices tell me how loud this noise actually is or at what distance from the amplifier it is no longer audible?
Greetings
Curdrone
Forget my request, I hadn't read through the entire thread and therefore only now discovered that Audiophonics meanwhile found a solution to this problem ...
