ribonucleic
- Joined
- Mar 22, 2023
- Messages
- 215
- Likes
- 230
Hmm... to me it looks like a hi-fi showroom. Fun to visit, but no place I want to spend many hours every evening.Why ? It looks to be a pretty well designed listening space, not some anechoic monster.
Reviewing cables is not the most attractive part of audio reviewing. Cables have so much influence on the overall sound that it’s sometimes scary. For instance, unplug a cable—no matter whether IC or power—and plug it right back in. The sound has altered. ...
LessLoss attacks environmental noise riding on power cables in a very special way. Though the Dynamic Filtering portion of the DFPC name suggests a filter, there is no filter as we know it in the cable, no capacitor or coil or similar. Louis Motek and his companion came upon the idea to invert the skin effect for slowing down rather than accelerating the signal portions affected by it. Slowed down sufficiently, they’d be effectively filtered out. The means to pull this off is a porous metal layer atop the main copper conductors which runs the unwanted HF content inside the porous metal maze where it literally gets lost.
LessLoss DFPC Series High Performance Skin-Filtering Power Cable
$1,149 / 2 meters
Says 6moons.com in their review:
I don't care what ASR says about cables. Cables matter. Unplug the cable and nothing works. Audible difference!LessLoss DFPC Series High Performance Skin-Filtering Power Cable
$1,149 / 2 meters
"Louis Motek and his companion came upon the idea to invert the skin effect for slowing down rather than accelerating the signal portions affected by it. Slowed down sufficiently, they’d be effectively filtered out. The means to pull this off is a porous metal layer atop the main copper conductors which runs the unwanted HF content inside the porous metal maze where it literally gets lost."
There is literally no science that supports this.
