ASR reccomended external crossovers?
tomtoo
Germany
But one thing i like to add
The question for me would be still is there a real benefit in soundquality to make them full-active? Or would it be enough to room eq them from outside?
Juhazi
Finland
If "them" is JBL 4367, I guess no. But in general definitely yes! Most commercial loudspeakers are not optimized to their full potential, that would mean too much work in the lab and too complex/expensive crossovers. One thing is that designers are trying to get the "house sound" apparent.
QMuse
IMHO, if you have good passive speakers their XO can be phase corrected very effectively and you will get "by the book" step response. Frequency EQ is anyhow a must in the region below 400Hz to compensate for the mess room is doing.
tomtoo
Germany
Yes i was thinking about the 4367. Ok thanks, at the top air gets usually thin.
Wombat
Australia
@tomtoo said. "At the top air gets usually thin". Please put that in physical or measurement terms. This is something mountaineers say.
Does air pressure/density in the proximity of the loudspeaker get reduced? Should asthma sufferers be wary?
Your above post is loaded with generalities. Please be more informative.
tomtoo
Germany
"The top air gets thin". Please put that in physical/measurement terms.
HeHe that would be a lot of cans with worms not only one. At least if we talk about this subjekt and not only about barometric measurements on mount everest. ; )
Wombat
Australia
Still waiting for an explanation. That avoidance went straight into the waste basket.
tomtoo
Germany
Ok, imo this is a top speaker. To be honest for me a dream. This thing is for me great, sexy, hot. At the top for me! Ok people maybe like there 5inch woofers with 1inch dome tweeters thats absolutly ok. But this things are for me great sounding and can give you a great punch. Thats top for me. Power-hifi at it's best. Formula1 level. Shure there are people that enjoy a ls3/5 more. But not me. So is this direkt enough for you?
Wombat
Australia
Still no rational explanation. I assume you don't have one and will end it here.
tomtoo
Germany
Rational? Whats wrong with you? Do they measure well? Think so. So you have them and you are unhappy? No problem get a different speaker. Whats your point?
watchnerd
Seattle Area, USA
Subjectively and in-room, moving from passive crossovers to more theoretically perfect DSP crossovers isn't a night and day experience when I've done it.
It's pretty subtle compared to fixing room issues.
Dynaudio makes speakers that use both methods and has a decent video on the topic, and subtly makes the point that the drivers and cabinet have to be good, too. They also discuss room impact:
Replacing passive crossovers with DSP crossovers probably gives better ROI on cheaper speakers that have budget-oriented passive crossovers or cheap drivers that need to be tamed.
QMuse
I'am a little upset the first time here on ASR so whats your point?
Oh, I noticed you met Wombat.. :D
tomtoo
Germany
After editing is boring. If you have to say something to me stay in the timeline. If this is not possible for you? You have nothing usefull to say to me. You get this?
Edit: imo you like to troll with me. Forget it.
Wombat
Australia
"At the top the air gets usually thin". What does this mean re audio. Simple question. Maybe you can get @QMuse to help you give a rational/technical answer rather than contribute put-downs.
You are not being trolled, only asked for clarification of a descriptor. You seem to be avoiding doing this, so the request was repeated. Forget it.
tomtoo
Germany
"At the top the air gets usually thin". What does this mean re audio. Simple question. Maybe you can get @QMuse to help you give a rational/technical answer.
Engineering top level. To make engineering thats on top level better is hard(the air get's thin). Maybe it's not that way used in english. Its a word to word translation from German.
It means the higher you climb the harder it get's to make the next step.
Edit: please make a point. If you dont make a point you have nothing to say.
Wombat
Australia
Thank you. Was that so difficult? I have learned something. :)
FWIW: The term 'air' is used subjectively by 'audiophiles' to describe something different.
tomtoo
Germany
Haha ok this was just missunderstandig. No it's just a saying in german. I used it word by word, thinking it's also used in other places.
No audiophile air. :)
