- Joined
- Jan 23, 2020
- Messages
- 4,340
- Likes
- 6,712
Wow! Some of the best measurements we’ve seen.
So it sounds like expensive drivers are unavoidable when it comes to certain minimum performance metrics after all?the directivity would be messier, and the maximum output would be lower. Getting a flat listening window would be trivial once you have an NFS and you're making an active design.
That about fits, but only if a high pass is used to protect against too much excursion at low frequencies.I did a quick sim, and it looks like it's just about an okay fit. MaxSPL is limited though, so I can imagine that Amir heard some ominous noises when playing loud. Here is the MaxSPL curve with the PR, I uses about 20 liters here, so real numbers might be a bit different:
Well, the speaker's low bass behavior was tuned rather neutrally. Nothing should stand out there.Im not saying it's not a successful design, I guess what I'm trying to say is that I'm disappointed Amir didn't have any particular reaction to the bass. I'm aware of what the purefi woofer can do on paper, but I wanted to read some personal impressions.
Exchange Purify for Satori WM16P. That should probably do it.
Ah, I used the 6 mm Xmax version for my sim. That would mean a bit more output indeed, but still a bit of a compromise in the end. A good one though I think. In the end, you want a small design with a relatively big low end, which this will give. Add a few subs, and this combination will do massive dynamics if needed.The Purifi woofer has a linear excursion of +-10mm and the mechanical limit is +-14mm.
The passive radiator from SBAcoustics has a mechanical limit of +-11mm.
This fits quite well, because at frequencies below 50Hz the PR reaches the limit of maximum mechanical deflection before the woofer and thus protects the expensive woofer (by making itself heard with "agonizing" noises).
In addition, the final fine-tuning is still missing. This usually changes the impression in the low bass range too.
You could buy two JBL 308p Mkii speakers (£300 for a pair when on sale) and use my Anechoic EQ, I think it might have better directivity even but not sure, following is a link to my post showing the effect of my anechoic EQ on the Listening Window & On-Axis, along with directivity plots from Amir:I'm talking about a commercially available speaker pair. How much does it cost to get the same performance? What would those speakers be? Anyone got any great ideas?
It's mention in the review it'd be in the 4-5k range,I'm talking about a commercially available speaker pair. How much does it cost to get the same performance? What would those speakers be? Anyone got any great ideas?
Not entirely. Revel uses SB Acoustics drivers (~$70) for their woofers, and a tweeter that costs about $50. I'm sure they're getting them a bit cheaper than that too. You lose some performance dropping down from the Purifi, but you do NOT need a $370 woofer to get pretty great performance.So it sounds like expensive drivers are unavoidable when it comes to certain minimum performance metrics after all?
Here you go https://www.audiosciencereview.com/...ource-speaker-review.27094/page-2#post-930096Super happy to see the Purifi treated well here and the speaker seems well engineered and yes still expensive.
So going off your lead.
To save money without losing a lot of performance.
The same tweeter here could be used with other known excellent woofers and come in under $500.
One superb option could be the Wavecore WF182BD (or CSS LDW7) at $150-160 each.
Thank you!You could buy two JBL 308p Mkii speakers (£300 for a pair when on sale) and use my Anechoic EQ, I think it might have better directivity even but not sure, following is a link to my post showing the effect of my anechoic EQ on the Listening Window & On-Axis, along with directivity plots from Amir:
Distortion of the JBL 308p Mkii is a lot higher though as seen in following pics, but if you don't listen at loud levels then I think it's ok and when I measured my speakers in my room I got lower distortion than that pictured here.ASR Directiva Open Source Speaker Review
Thanks for the write-up, Rick! So your starting point was already chosen so that the budget goal was already hard to reach? Luckily the excellent tweeter is budget-friendly :) Also, this budget does not include the active parts, does it? Amir's amplifier already costs $999, and you need two of...www.audiosciencereview.com
1m listening distance, 1 side wall ~ 1,5m away.
This is kind of my point. You're paying a lot for miniaturization. For me, it makes more sense to just use subwoofers, or build a larger speaker (traditionally this is where DIY becomes a good value)Not entirely. Revel uses SB Acoustics drivers (~$70) for their woofers, and a tweeter that costs about $50. I'm sure they're getting them a bit cheaper than that too. You lose some performance dropping down from the Purifi, but you do NOT need a $370 woofer to get pretty great performance.
feel like I'm taking crazy pills
"Genelec 8040s" and "cheaper woofer" throughout the thread... does nobody look at the frequency response? This thing's LF extension is absolutely exceptional, and that is largely because of the expensive woofer. The distortion measurements are absolutely spectacular. It is +/- 2dB, starting at the exact frequency where the 8040 is down 6dB!
These ideas to replace the woofer with a cheaper one to get the BOM down... okay, I guess??? It becomes a completely normal, unexceptional speaker in that case. Dozens if not hundreds of those designs have already been done.
If anything, I want to see this same design with the newer, presumably even more expensive, Purifi 6.5 woofer that has even more excursion... the only cheaper alternative woofer mentioned in the thread so far that stands any hope of maintaining this level of performance would be the XBL^2 woofer from Misco.
I would argue that absolute output level and extension are more important than distortion. I'm not sure how this speaker performs in that respect; it seems like the PR and the tweeter would run out of steam before the purefi, but I await comments from the designer.
Let's not compare this to a Genelec. This is a DIY project, and it is a unique value proposition.
