ROOSKIE
Super happy to see the Purifi treated well here and the speaker seems well engineered and yes still expensive.I’d like to see what can be done to a low price point - maybe $300 in materials for a $1000-1200 commercial design. That would be much more complicated, and it’s not my time being spent
So going off your lead.
To save money without losing a lot of performance.
The same tweeter here could be used with other known excellent woofers and come in under $500.
For a real budget, you could deff get near $300 if one went with Dayton RS woofers though they are not nearly as unique. My RS180 woofers are a superb value @ $120 or less for a pair.(2)
SB acoustics has their myriad options for around $100-125 each.
Misco has 2 newish woofer out with nearly the excursion of the Purifi and they are
$135each
6.5 Inch (165 mm) XBL² High Excursion, Low Distortion Woofer
MISCO has taken the XBL² technology and executed with effectiveness and elegance in the BWX-6501 (82109), 6.5” woofer. By using a high energy neodymium ring magnet, a high BL is maintained while the magnet structure size and weight is minimized. Yet the Klippel verified, linear XBL (BL force...
store.miscospeakers.com
6.5 Inch (165 mm) XBL² High Excursion, Ultra Low Distortion Woofer
An exceptional 3-way pro-audio woofer that reproduces the clearest low-end frequencies while matching the excursion of a classic 10" woofer, delivering minimal distortion and maximum audio enjoyment. 6.5" (165 mm) cast aluminum basket 85 watts, 8 ohm, 85 dB SPL 9.5 mm linear excursion Neodymium...
One superb option could be the Wavecore WF182BD (or CSS LDW7) at $150-160 each.
The old standby Anarchy woofers could be an option for much less than the Purifi.
All of these designs can use a port that fits the box, or there are passive radiator options. The issue with the Purifi is it basically requires a radiator due to port length. The other drivers will not, though that radiator might still be part of a sweet design.
As you can even see here confirmed via @voodooless, the radiator chosen is likely stressed at really high volume and the system even needs a larger one to truly be optimal. It seems the Purifi is just a tough driver to work with in a small box.
PS, for the right person. If one could get ahold of the woofers in the JBL l82 that would be sick, though not a good idea for a wide release. Likely they are hard to get and only from a few sources. They are incredible 8's in my humble opinion and the distortion I have measured of the speaker is low.
Anyway it great to the Purifi can work well, I am also excited to see if a less expensive woofer in a ASR speaker is on the table.
I have that tweeter here, the only issue is no waveguide. I think here @ ASR that is not going to fly.This could be a good alternative to the Seas tweeter. Goes down to 1.5khz with zero problems(Even lower with an 8th order) and will most likely fill the vertical directivity hole.
I am planning to partner mine with a few different woofers and see what I can get. That tweet is beast.
