- Thread Starter
- #121
Not in the plan. But there will be new stuff in that price range. So stay tuned.Are there any plans to release the E50II?
1, 1% coffee 99% teaHi John
Coffee or tea?
Peanut butter or jam?
Whipped cream or chocolate sauce?
But you still do need files to play? It's not like DOP is automatically converting PCM to DSD. Also AP doesn't directly support DSD, we play on foobar and tunebrowser.(personally foobar)Why test files,you can measure straight with Multitone up to DSD256 (DoP)
I don't like HQplayer. Difficult to use, -3db at least full scale. Jriver is honestly better in all practical sense. And even foobar itself is good enough.My test files I created using HQPlayer Pro version (pkane knows this software).
Upsampling REW PCM test files to DSD
But yes Multitone Analayzer is a good all in one to test DSD256 @JohnYang1997
From what I saw with broken DSD output performance, no DSD output analogue measurements were done
Hopefully Topping can actually test in design and QA/QC
Especially broken has been DSD Direct mode topping DACs - ess no issues
We disabled DSD direct mode in E70V. So the only one you could probably talk about is E30 II? I have personally saw it working fine on DSD files but can double check it later.My test files I created using HQPlayer Pro version (pkane knows this software).
Can't wait. I need a 430mm wide amp, preferably in silver. 2 x 200w into 8 ohms would be niceTP branding is for that.
On more powerful amps, yes and yes. But not all in 430 format. In TP branding yes.
When I say DSD is worse than PCM I'm not talking about 3dB worse THD+NWe disabled DSD direct mode in E70V. So the only one you could probably talk about is E30 II? I have personally saw it working fine on DSD files but can double check it later.
All of these have to work perfectly fine before production, so we definitely do do the testings.
With Multitone Analyzer is simple,it's generator is playing straight DoP (and PCM of course),you just have to choose it.But you still do need files to play? It's not like DOP is automatically converting PCM to DSD. Also AP doesn't directly support DSD, we play on foobar and tunebrowser.(personally foobar)
Speaking of JDS Labs, I would like to ask when you will support UAC1.0? Don't forget PS4/PS5 or Nintendo Switch users.1, regarding resellers, we have regional resellers that are doing better like Apos, Audiophonics, Addicted to audio. But we will put pressure on other resellers to give better service.
2, I am aware of how much reputation has fallen around here. But the thing is more complicated
1) Although not much increase, in the poor economical environment we don't seem to have decrease in sales. So in a way ASR may not cover enough user base. It's weird thing to say but it's true.
2) The general consensus here has changed a lot. Not many chases after the last bit of performance like before. It may because it's not audible (but noise is certainly audible in some types of devices). It may be it's over the ap555's limit.
3) But again like the first, the people here(at least comments) are a bit different than what's shown on sells. People here seem to be much more sensitive to pricing. When the lower cost brands/subbrands came they draw a lot of attention. More casual buyers may not care about performance or too much on pricing anything like that if they feel like to buy they buy or they get recommend by friends.
3, our biggest market is US. So it's automatically a benefit to be domestic brands like schiit(and JDS and other amp builders in the US). People in the US are more comfortable buying US brands especially when they don't cost more. We import components from the US, and we distribute via resellers so it adds a lot of cost just to get to the US. On the other hand like in AU it's more appealing to buy our products or AU's domestic brands like burson. So the biggest thing in between is the reseller. Our new TP branding doesn't have resellers but ourselves so it maybe inconvenient in some way but it's a choice. Then the usual Hifigo, SZA thing. It's difficult. SZA is the biggest reseller in the industry, we can only do so much we can't control them. And we need other resellers to compete with SZA. And even Apos sources. from SZA. So basically it's a mess. Simpler situation is either go with apos, audiophonics, A2A or directly from us. We are looking for more regional resellers especially NA but again difficult. Recently we are looking at making the pricing in AU match the US pricing but then it requires discussion, time, people to do.
4, on the reliability, yes we are putting more and more resources onto this. We have kind of worked our way out on how to achieve the result we want. So in the future it will be much much better. Sometimes it amazes me other brands don't have these issues or maybe they do just not to the scale maybe or simply people don't care about those brands so minimal reports. So in short we have upped our game in testing before production and testing after production. And continue improving largely in coming 1-2 years.
And the question was?I concur decently performing AVP’s are simply unicorns it would be a game changer even you used it for only 2 channels, you get a digital preamp with room correction and subwoofer xover .
Sound quality of a DAC is a solved problem, the DAC should be commodity used inside more interesting products.
If you can’t handle the hdmi/Dolby/dts licensing mess .
Some kind of 2 channel preamp with both digital and analog inputs and DSP and subwoofer integration would be very interesting.
I would not hold my breath, it’s an massive software undertaking in a business where it’s the norm to have shoddy and buggy software.
But one can always hope![]()
.. any plans for such a productAnd the question was?
Any chance of licensing class D tech from Hypex, Purifi, ICEpower (they have an interesting new design coming)? So that you could use your own or 3rd party power supplies, and instead of chip amps, use higher end discrete designs licensed from them, but the board built by your suppliers? Like NAD does.I have tried for two years with self oscillating class D. Minor success in the beginning but due to some critical problems that I can't solve I pretty much stopped the development.
I agree but remember that Topping is a 45 person, niche manufacturer. Most AVR manufacturers have more staff at their offices in various countries. AVR/AVP is a huge undertaking from licensing to stock to distribution... any plans for such a productTopping in the AVR/AVP market ? it's completely stale and ready for some disruption ( you can argue that it already happened with soundbars and earc capable lifestyle speakers )
