- Joined
- May 30, 2024
- Messages
- 423
- Likes
- 3,645
- Thread Starter
- #41
In the frequency response graph, the C5B appears to go deeper frequencies than the C6B. Although designing a larger enclosure for the C6B would allow for extension into deeper frequencies, this would result in a larger overall size.Are the measurements at spinorama.org flipped?
Alternatively, adding weights to the passive radiator can achieve lower frequencies, but this comes at the cost of reduced sensitivity.
The C6B outperforms the C5B in terms of maximum SPL, sensitivity, and THD at high SPLs.
The difference in tonality scores is minimal, so it can be considered that both models have the same tonality.
Currently, the test data for the C6B shows a slight bump in the 60-70Hz range. By adding a small amount of weight to the passive radiator, it is easy to achieve an FR graph similar to that of the C5B.
