He is talking about the speakers rated sensitivity @2.83volts not @1watt.
Nobody really uses sensitivity ratings @1watt anymore.
2 speakers rated at 81db sensitivity at 2.83v do not have to have the same impedance.
An 8ohm speaker and a 2ohm speaker could both be rated at a sensitivity of
[email protected].
Very different draws on the amp.
One breaks many amps, but even if it did not most amps do not double output as impedance halves so you lose something even if it handles 1&2ohm loads.
Beyond that obviously a 5" woofer based speaker with a 81db/2.83v sensitivity is going to require 4 times the power of an 87db sensitive design for equal SPL meaning the amp will often be driven hard unless you never listen at louder levels.
Now imagine a 8ohm nominal load with 87db sensitivity(very rare for any small 5" monitor, it would typically give up all low bass ability --> which is fine in subwoofer use cases) vs a 4ohm nominal with 81db sensitivity.
With that low sensitivity and 4ohm nominal (with typical dips well below and possible hard phase angles)The amp is going to work so much harder and therefore the cumulative of whatever % is lost to heat is so much greater. With certain amps this is no issue with others it could be.
If you buy these buy a very solid amp.
