IIRC Stereophile did a study which showed that if the equipment had gold panels people thought it sounded 'warmer'. But in the case of tubes it actually is more than that
That simple fact is evidence that not all solid state in the past has brought home the bacon. I doubt this will ever get seriously researched so its down to conversations on audio websites, which IMO/IME usually fail to get to the nub of it, so the conversation has been ongoing since the inception of the Internet (which preceeds the WWW).
Lined out portions are false; snipped portion is a violation of website posting rules so is not repeated to avoid owning the violation.
I think 10%, even if mostly 2nd harmonic, is too much. That is one reason I'm not a fan of SETs. Not the only reason by any stretch... an elliptical load line is no way to run a power tube, you can't make bass with any power (or the OPT would be the size of a small refrigerator to get the inductance needed). There's a really good reason PP amps supplanted them. I don't want to digress on this, its easy to get me started on the failings of SETs.
I never set out to make the 2nd and 3rd audible (nor do I know any designer who does that with intention) and made our tube amps fully differential in order to cancel even orders throughout the circuit (so tend to produce a dominant H3 rather than H2). I see it sort of the other way around, which is tubes need to go away and to that effect, solid state amp designers need to make their amps 'sound' correct such that tube amp users will abandon the tube amps for something better.
Keeping in mind of course that tube amp users tend to own tube amps based on 'sound'.
I think this is happening right now- a lot of the current crop I'm seeing have what
I think is the right distortion spectrum, don't have distortion rise with frequency and lower THD so should be greater detail (since distortion obscures detail IME) and
just as relaxed as the best tube amps. FWIW, tube users often have complained over the years that solid state amps have more detail but that comes with brightness- so much so they conflate the two! I think you're on the right path when you get both detail and a relaxed presentation at the same time. BTW if you've not seen it, Bruno Putzeys, who had one of the lowest distortion amps ever, just did himself one better! BTW, apparently Bruno thinks the way I do about all this, if we are to take some
comments on the Purifi website seriously (note 'harsh sound').
I love your 2nd question! I ask people the same thing- if you can get
all the benefits you associate with tubes (greater detail, relaxed, smoother presentation, the ability to listen all day yada yada) in a solid state amp, why do tubes?? They are more expensive, noisier, more heat, less reliability, warm up time (which might take over an hour)...
3rd question: 0.1% is plenty!! 5 or 10% is too much as you lose low level detail- its harder to make out vocals, stuff in the background and so on. All
very subjective stuff here of course, but I hear about it
all the time.
