- Joined
- Dec 12, 2019
- Messages
- 16,463
- Likes
- 37,379
Flawless logic!As long as musicality is not defined, then YES, tubes are the most musical.
But -- I'm the best Keith Moon-style drummer that I know of!
Where can I see this?0.004 but look at what happens at higher frequencies when bridged- up by a factor of 5 at 10KHz.
There's the tinkering with different tubes... "oh I finally scored this 1959 Western Electric" and what not. Kinda like vinyl with cartridges and such. I am in no way condemning it, to each their own, but it's a bit of a clash of audio cultures rather than a technical discussion at this point.I'd assume they are still around, because some people (like with Nixie clocks), like the way they look. I assume some people think they like or like the way they sound.
His bridged link in an earlier post goes to the 565 owner manual. Post #192.Where can I see this?
The info is on specs near the end of the manual.
It is defined. What music is has been adequately understood for a long time. It's the difference between a song and white noise. The difference between a melody and a heavy diesel truck changing gears.As long as musicality is not defined, then YES, tubes are the most musical.
The problem can therefore be posed theoretically but I don't know who wants to take up the challenge to answer it. I don't think it's my job.
Most of us here at ASR can more-or-less understand a theoretically transparent amplifier. So let's take that as a baseline. Relative to that, How does a non-transparent amplifier add music to the input signal? Purely in theory, no anecdotes, no data.
Ok. I have an idea, the extra-musical amp could inject Bach cantatas when it detects silence on the input so you can get more music out than you put in.
I know Basinski very well. For several years I counted my own music in the noise genre. It's perfectly clear that it was music because music is an intentional social practice. Talking about the fuzzy corner cases doesn't change the basics, kinda like the concept of spices in biology.Music is art. Art is made, therefore defined by people. Even trucks & changing gears are somewhere in the music world, for sure. White noise? Check Basinski.
So no, technical defintion of music does not work.
There is nothing so enduringly fashionable as nostalgia.The old Hi Fi vs. Fun Fi. Nothing new.
Seems to me the most likely explanation of the musicality of tubes is in the art of our mind's eye.
Indeed. We just have a disagreement about what that is. And you're doing everything you can to avoid demonstrating that your hypothesis is valid.Its a bit pesky when something sounds bright but you put it on the bench and FR is flat. So something else is afoot.
No, but it was a horribly flawed demonstration not to be taken seriously.The Carver Challenge already forgotten?
The Carver Challenge | Stereophile.com
Thanks for posting this 1985 article to your website. I bought a Carver m1.0t amp in 1986 (without ever having seen a copy of Stereophile) and it has served me well ever since, with one repair and adjustment to factory specs (total repair cost was $200 in 2006) needed in all of that time. It's...www.stereophile.com
Once we've divined the place of musicality in tubes I guess we can move on to R2R Dacs which of course were lambasted mercilessly for their cold analytical nature upon their introduction. Yes, Nostalgia is grand. Just a couple of generations later and those DACs are suddenly wonderfully musical. Some even call them analog-like.
Those idiotic old stereo demonstration records could lead this in a whole new direction in which I am the reactionary. And I think you all know what I'm talking about. Starts with an I and ends with aging. Thankfully that's another thread and we've done it often enough before.Yes, it's an LP of choo-choos and thunderboomers.
