I like the summary: 9/10
Pros
Cons
- Superb sonic performance
- Four separate subwoofer outputs
- ARC Genesis produces excellent sound with zero hassle
- Rock solid build quality
- Tremendously easy to use
- Comprehensive set of connectivity options
- ARC Genesis may be too straightforward for some
- Cheap remote
- The AVM 70 exists!!!
Actually, half of the cons he listed are pros to me too because I did get the 70 and Anthem has since addressed the "straightforward for some" part by adding some target curve adjustability features as well as phase adjustments for all speakers.
Cheap remote is true but the app is quite easy to use, not sure if the one for the 90 is better. For the huge price jump, everything better be much better anyway.
