ArturoKiwi
- Joined
- Feb 13, 2020
- Messages
- 259
- Likes
- 116
So, previous generation (avm60, mrx x20) has Arc Genesis
So are you saying that Anthem just told dealers the are the same and we should all buy the AVM70?
But they get more money by pushing the AVM90 especially with margins being 40 points off MSRP
Honestly feel that’s hype, I’m sure it probably does measure better. And I say probably cause most likely it could possibly measure worse or the same.Not what I said, sorry for not being clear. I don't know what Anthem told the dealers. I only know the dealer I bought the 70 from told me the 90 sounded better to them and that we (2 of us customers there) that we would be able to hear it. And there was no side AB setup to compare the two.
Knowing you seem keen on the best available measured performance I would say it was lucky for you that you missed the 8012. That one measured not much better than the likes of the SR6014, typically much worse than Denon's. The only one that is comparable or even better in some ways than the Denon AVRs (the AKM DAC onboard ones) is the SR8015, that has the best measurements among all Marantz AV devices including the USD5,499 flagship AV8805A.I think my only regret was not buying the 8012 for 2099 back in 2020. Cause if I had bought that I wouldn’t have upgraded now. I plan on keeping this[avm70] for 6 years at lease before I upgrade so it’s worth it for me and highly probable I will keep this unit until it’s dead.
At 3700 no chance, plus tax I would be at 4100
That is why I am so undecided. At the same price there is SR8015, Cinema 40 and mrx1120. Sometimes the avm60 is a little cheaper.Knowing you seem keen on the best available measured performance I would say it was lucky for you that you missed the 8012. That one measured not much better than the likes of the SR6014, typically much worse than Denon's. The only one that is comparable or even better in some ways than the Denon AVRs (the AKM DAC onboard ones) is the SR8015, that has the best measurements among all Marantz AV devices including the USD5,499 flagship AV8805A.
Comparing the new one SR8015 is 1000€ cheaper than the AVM60. If you compare them used is the avm60 to be cheaper, about 700€I think for most, if not all, people won't be able to tell a difference between the 8012 and 8015, just nice to know your unit has better measurements. If I can get the 8015 and the avm60 I would definitely take the 8015 and use it as preamp mode, but I doubt you can get them for the same price.
I am selling an AVM 60!That is why I am so undecided. At the same price there is SR8015, Cinema 40 and mrx1120. Sometimes the avm60 is a little cheaper.
Oh really? Thought the 8012 was a decent performer. Maybe I did dodge a bullet lolKnowing you seem keen on the best available measured performance I would say it was lucky for you that you missed the 8012. That one measured not much better than the likes of the SR6014, typically much worse than Denon's. The only one that is comparable or even better in some ways than the Denon AVRs (the AKM DAC onboard ones) is the SR8015, that has the best measurements among all Marantz AV devices including the USD5,499 flagship AV8805A.
You can always try the 6700H I seen them selling for probably 2600 your price.Comparing the new one SR8015 is 1000€ cheaper than the AVM60. If you compare them used is the avm60 to be cheaper, about 700€
I can also confirm that my AVM70 has the ES9010K2M... Maybe this explains why I'm not too impressed with the sound. The review done by Amir showed how good the unit meassured, thus I was very surprised by all the distortions and clipping I have encountered (several others have repported this behavior too). Maybe they rushed the "swap"?
Hello.
When looking through the lid, I can see an AKM 5574 ADC. Can’t see the DAC’s.
but since it has an AKM ADC, does that mean that the DAC’s will be 4490EQ?.. or can the DAC’s still be ESS DAC’s?
Probably what then?.. a bit confused, I actually asked two questionsProbably, mine has the ES9822pro ADC, just not sure about the DAC. Do you know which FW version yours had out of the box before you update it? And when was it shipped, approximately. That might be a good indicator but may be not.
Did you see the ADC through the lid in the top right corner? ..
You mentioned one that took a photo of the ESS 9010K2M (attached!) - a guy on avsforum did that. Funny he found an 9010K2M when looking the same place through the lid.. but is that not a DAC, and not an ADC? (I really don’t know much about chips…)
I don’t know about which FW it had when arriving. I also bought it used. I do know the former owner got it as a replacement around May 2021.
Hi guys, I'm new in this forum so maybe you have already addressed this question but I would be very grateful if somebody could clarify. How many volts VRMS does the XLR outputs of a AVM 70 put out what I can see on their website it should put out 10 VRMS or am I reading this the wrong way?
PREAMPLIFIER (MEASURED AT XLR OUTPUT) | |
Maximum Output (<0.1% THD) | 10.7 VRMS, Subwoofer 11 VRMS |
OK, thanks for the reply, but would it be any difference in sound if I were to buy a processor instead of anthems AV amplifiers because they can output 5 VRMS.You are reading it right, the manual says:
So expect 5 V for the RCA outputs
PREAMPLIFIER (MEASURED AT XLR OUTPUT) Maximum Output (<0.1% THD) 10.7 VRMS, Subwoofer 11 VRMS
I am sure you already know but would still like to mention that in most cases, for normal use it will likely output no more than 2 V, in my case probably less than 1 V even during ithe highest peak for music or 1.5 V for movie when I really crank the volume up. The actual maximum is will depend on your speaker's sensitivity, listening distance, maximum spl you need, power amp's gain, power amp's maximum output, and the contents you watch/listen to.
