I recently got the Ampion Argon1s in for review. Though I haven't had time to run the full suite of measurements (hard to find the time to run 70 sweeps without annoying my SO) I did run some horizontal measurements today. I'll probably redo them as they were a little more rushed than I'd normally like, but they should be representative. Thought I'd share in the meantime.
Edit: Finished them!
Here's the spin:
Squishy scale(approximately matching Amir's reviews):
Horizontal 0-90:
Polar:
Vertical 0/5/10/15 and Ceiling and Floor Reflections:
Polar:
Measured @1m, gated at 6.5ms. Measured on tweeter axis - was flatter than between the woofer and waveguide.
Some thoughts so far:
Enjoying them a lot so far. Bass keeps on surprising me for 5 inch woofers. Timbre sounds neutral, and vocal clarity seems to shine. Amphion says it focuses on keeping the region from 2-5k neutral, and I think it shows in the sound. And i like the minimal design and customizable colors (I have the blue grilles).
That's all for now.
Here's the spin:
Horizontal 0-90:
Polar:
Polar:
- On-axis rising treble. I can't say I 've noticed it much perhaps because this region also drops off pretty quickly off axis. Strangely, I noticed similar rising treble on the Sonus Faber Sonetto II way more, but I have hearing up to 19kHz or so and that one is more egregious high up. That said, I have preferred the Argons them with minimal toe-in.
- Flattest measurements is about 15-30 degrees off axis, which matches more typical at-home placement with less toe in. Might be a conscious choice. Unfortunately, Amphion provides no placement guidelines in the one-page manual, but they do show it with no toe in in promo images(who knows if that has any engineering merit though).
- Quite nice horizontal directivity behavior overall.
- But unlike some big waveguides, this one doesn't seem to extend directivity of the high treble very much ( like, say, the Buchardt's).
- Messiness from 400-900Hz. Can't say this is particularly audible with regular music yet. Changes with angle so I suppose it balances out.
- Taking 20 degrees as the direct sound, a pretty smooth response otherwise, with minimal jaggies and clean looking off-axis radiation.
That's all for now.
