Measurements of Amphion One18 and Amp500
JIW
Germany
From Sound & Recording.
Those are/were quite popular with audio professionals - even hyped. Can't quite see why.
Price is 2700€ for the speakers and 1560€ for the amp. A pair of Neumann KH310A costs about 750€ less and is much more accurate. Similarly, a pair of Genelec 8350 with GLM kit costs about 300€ less and is also more accurate. For 400€ more, one could even get Genelec 8331 with GLM kit which are more accurate and have exceptional dispersion.
Power at 2x4Ohm. Striped: 100 Hz. Straight: 1 kHz. Dotted: 6.3 kHz. Measured with APx555 and AES17- and AUX-0025-low-pass-filters.
SINAD at 5W is between 90 dB and 94 dB and clipping point seems to be around 250 W at SINAD of 60 dB. Residual noise seems to be around 27 µV giving a 5 W SNR of 104 dB and SNR at 1% THD+N (320 W) of 122 dB. While noise is fairly low, this is still far from impressive for 1560€ and the March Audio P502 delivers similar performance at about 60% less price ($1075 is 966€).
Frequency range: 56 Hz – 19,3 kHz (–6 dB)
Deviation: ±3 dB (100 Hz — 10 kHz)
horizontal opening angle: 120 degrees (–6 dB Iso 1 kHz — 10 kHz)
horizontal standard deviation: 18,3 degrees (–6 dB Iso 1 kHz — 10 kHz)
vertical opening angle: 127 degrees (–6 dB Iso 1 kHz — 10 kHz)
vertical standard deviation: 20 degrees (–6 dB Iso 1 kHz — 10 kHz)
max. usable SPL: 101 dB (3% THD 100 Hz — 10 kHz)
Bass ability: 94,3 dB (10% THD 50 — 100 Hz)
Max level at 1 m (free field) with EIA-426B Signal at full scale: 94 dBA Leq and 109 dB Peak
Paar deviation: 1,7 dB (Max value 100 Hz — 10 kHz)
Noise level (A-weighted.): 3 dB SPL with Amp500 at 10 cm distance.
Dimensions / Mass: 191 x 380 x 305 mm (W x H x D) / 12 kg
Yawn. Another mediocre active monitor propped up by a cult of personality - think ATC and PMC. Infuriating to see them constantly propped up.
They are actually passive using a passive crossover and external amps. Different than the JBL M2 or 705/8i which use external amps but active crossovers.
I often see biased posts like this, followed by several likes on here..
Anyways, I was also biased in that I thought their point source claim was untrue but these measurements show really good vertical directivity
Last I checked a 550Hz 3dB peak smack in the midrange wasn't necessary for good vertical directivity. Nor can anything with such a peak pretend to be accurate
I thought the speakers' response measurements look very odd. And they sell at fairly premium prices. So this is a reasonable hypothesis, and not the first speaker that attracts some strong brand identity. I find many of their marketing claims rather suspect.
But for sure the directivity looks good. But the frequency response is going to stand out like a sore thumb. I think it's OK to expect way more, right?:)
All that being said, it does look like user-applied EQ can help this speaker, assuming the rest of the data is accurate.
The thread is a few years old, any new data to share?
I didn’t even notice the frequency response having that. Looks odd for sure. To be fair, amphions own measurements share this, so at least they aren’t hiding it.
I actually came across this because I didn’t know of any measurements done by anyone on Amphion speakers, so after seeing the vertical directivity, I only have questions.
Now that I know that speakers that DONT have coaxial drivers, I am now curious why more regular speakers with separated drivers don’t have a point source directivity (good vertical)
Amphion crossover is at 1,600 hz.
DD8C is at 1250 hz, yet doesn’t have nearly the as good vertical directivity.
Reactions: MAB
Not for the One18, but there are some measurements of Amphion’s home-marketed variant by some schlub here;
Thanks!
Instead of the pointless “more treble” switch, an option for a broad cut of about 2dB centered at about 10kHz would be a very nice addition to the Argon 3S.
Made me laugh and agree at the same time.
Yeah, it's a mixed bag.
I want to like them a bit more.
I will admit, the vertical spin data confuses me given the large DI mismatch at the crossover frequency. Here is the data from Jay's review, I think the two speakers are comparable.
The website linked to originally has changed and the links are dead. It has been archived, however. The images lacking in the original post are posted below. I may update the other links later, if I find archived versions.
