"To establish the Harman curve, the team conducted a series of blind tests with 283 participants from four different countries across 11 test locations."
Even if you shift the curves to meet at 2 kHz they should keep their form and in the range 200-500 the curves are on top of each other.
It seems a bit like we are at the start of round 2, where most aspects will be repeated.
Before that happens, I would like to introduce some slightly new things. (Maybe I fail.)
The graph from the very first post shows the result of a study with 11 participants, 7 °trained" and 4 "untrained". That makes the statistics somewhat shaky. Maybe there is abundant other data to support this but nothing has come up here so far. So I take this at face value.
The average of four preference curves of untrained listeners seems to me to be not reliable enough, I would discard it. At best it can give some hints at the difference between the groups. I would discard the curve for the full group too, as it is an average of two obviously differing subgroups.
So I am left with two curves (I kept the normalization at 2 kHz):
- "Trained Preference" (black), the averaged (and smoothed?) preferences (FR at listening position) of seven trained listeners adjusted in a good room with a well engineered speaker. The curve is quite close to a -1dB/oct tilted flat curve.
As I understand, Toole made clear that the trained "preference" curve is not supposed to be a (general) "target" curve. The reasons are not so clear to me. Is it because the curve not general enough (only one speaker in one room)? Other reasons?
- "Predicted FR" (red), the expected FR of the well engineered speaker in the room without adjustment (flat direct sound). This curve does not look like a measurement but more like a theoretical, idealized expectation. I will assume here that the "predicted FR" is indeed close to the smoothed, unequalized FR in room of the speaker in the study. This FR can be approximated by a -0.5dB/oct tilted flat curve.
I added the smoothed (1/3rd octave) PIR of Genelec 8341 from Amir's test for comparison. The speaker in the study looks like having a rather wide radiation pattern (even wider in HF than the Genelec).
Trained listeners seem to accept (actually prefer) a considerably altered on-axis curve in return for an adjustment of the room frequency response, because the "trained preference" differs from the "predicted FR" that might be seen as the "natural FR" of the speaker.
It seems like the trained listeners prefer more LF and a reduced level in HF (a more tilted FR) than this speaker produces with flat direct sound.
EQ is plotted in yellow.
This rises a couple of questions.
Is a flat direct sound - contrary to general wisdom - not the most preferred option with wide speakers?
Would a speaker with narrower radiation that combines flat direct sound with a more tilted in room FR be preferred over the speaker in the study?
| Black: Trained Preference | Green: -1 dB/oct (dark) ±1dB (light) |
| Red: Predicted FR (of speaker in room) | Red: Shifted Copy of Predicted FR |
| Yellow: Approximate EQ for Trained Preference | |
| Blue: PIR for Genelec 8341 (smoothed) for comparison | |
