- Thread Starter
- #101
As I stated in the review this issue is difficult to resolve. It will take more listening experiments and recordings with additional, carefully chosen, various test signals. The only conjecture I can make based on the measurements for now is that the artifacts, if audible, would be significantly less audible for the devices tested not producing the Cirrus hump.In practical terms, would you say devices not affected by Cirrus hump in the first scenario, like Jcally JM20, are much better than the ones with Cirrus hump? what I mean by this is if it's better despite still having the issue in part II?
That is to say, in the case these issues could be audible in some real-world scenarios, is it likely that JM20 without the cirrus hump ends up with all or most of these scenarios not audible because you are less likely to be in the scenario of part II compared to the scenario in part I?
