audiosciencereview.com
That seems a reasonable presumption. But this owner of Beolab 17's experienced a very noticeable difference:
Master Thread: Are Measurements Everything or Nothing?
All dacs sound the same even they doesn't have the same measurements. Here's where I absolutely disagree - from firsthand experience. The DAC I'm using atm is that on my Musical Fidelity KW250s - taking the optical output from Chromecast Audio. Then out from that to my active speakers, Beolab...audiosciencereview.com
It would be interesting to see its score also for the vertical orientation which is recommended for a stereo pair where it switches off the the side drivers to radiate more directionally and becomes a mono source.It has a preference score of 2.9, so normally it wouldnt make my list.
Thanks, very helpful indeed. So when streaming wireless to the Beolabs 17, the DAC of the streaming device (for instance WiiM Pro Plus) is not in play. Does that mean that the cheapest streaming device will give the same result? After all, digital is digital.The Beolab 17 would always use its own DAC for TOSLINK and wireless. There's not really enough info in that post about the 17s to determine level matching, toslink parameters, source material, etc.
The 17s are a digital speaker. Here's a block diagram of it. All the analog inputs go through an ADC and then the same DSP as the digital in and then the same DAC as the digital in. Nothing is connected directly to the amp. So I don't know what the poster in that other thread is measuring, but it's not the performance of the Beolab's DAC. This figure is from the 17's service manual.
The 17s do have an acoustic lens for the tweeter, so they are pretty focused on a main listening position. If you stand in different places, they will sound different. I'm not sure if the poster on the 17 listened to them in the same spot.
B&O gear is, IMO, primarily for the looks and style and secondarily for the sound. I had B&O for maybe 20 years. It's good sound, but it's excellent style. I had Penta 5 and Beloab 4500 and Beolab 6000, none of the newer stuff.
I'd say go to a B&O store and listen to them over wireless on songs you know well. Of course, that will likely be in a treated room, so YMMV at home.
B&O put a lot of effort into their wireless system (and thus DAC), so my presumption would be that it's not crap. But of course, I'd want to hear/measure them in a controlled experiment. I would want to see more quantitative results than one person's anecdote.
Maybe this is of some help
B&O Tech: Beolab loudspeakers and Third-party systems
#77 in a series of articles about the technology behind Bang & Olufsen loudspeakers I’m occasionally asked about the technical details of connecting Bang & Olufsen…www.tonmeister.ca
I'll visit a B&O store soon to listen myself
In my now 67 years I have NEVER been to someone's home that had a treated rom. I have been long term in the USA, Europe, Asia, the islands & atolls of the Indian Ocean, The Western Pacific, Oceana. As to South America, unfortunately the closest I've been is through the Panama Canal 14 time and 4 hour in Panama.since many of these will be used in treated spaces could we possibly have something like a "treated room preference score"? because afaik the standard one has big emphasis on dispersion which becomes much less relevant in a treated room.
on a sidenote: i would go as far as even giving less emphasis on the FR, cause we are all EQing. the T5V HF boost is very easily EQed for example. done that it seams to be a better product than the Kali LP-6v2 for example
I would love to see a treated room before I die.
I've heard people talking about doing it since 1977 or so. But I don't know anyone right now that has done it.Interesting. Here in Norway I'd say at least 50% of the people I visit have treatment to some degree. Everything from a few commercially purchased acoustic panels or a slatted wall, to people with commercially installed perforated walls or ceilings, all the way to DIY people with completely open either walls or ceilings (thin fabric over insulation). Others again just have a normal room of course.
But I'd say in the later years more and more people have opened their eyes to the impact of the room.
