I would like to upgrade my JBL Studio 530 bookshelf speakers in my living room. I have a HSU sub with a dedicated amp (the built in amp failed) that I plan to keep using. The living room is 20’x20’x10’ and it’s open to the rest of the home, so it’s a large area. If possible. I’d rather avoid large speakers. Budget is not determined as of yet. I’m definitely looking for value. I’m willing to look at speaker kits.
1. Help me understand the speaker reviews posted here. Plenty of speakers have a high score and a low “rating”. Is the rating factoring the cost of the speaker? Should I ignore the rating and just look at the “score with subwoofer”?
2. I was looking at midfield monitors similar to the Adam A77x. I like that they can be used horizontally. Wide speakers would work well on my entertainment center, but tall is not ideal. Is it ok to use nearfield monitors? I’ll be seated roughly 10’-12’ away from the speakers.
