A $15k music streamer reviewed on stereophile
Killingbeans
Bjerringbro, Denmark.
I'm glad some picked up on what I posted, yep, old fan here. Did you ever see the movie length cartoon in 1986?
Didn't know there was a movie. I read the Danish translations of the comics, and that was all I had. I probably had no clue what New Zealand was back then, even though there was a map on the first page pointing to Gisborne :D
fragzone
That doesn't make any sense for numerous reasons... where does the review say this btw?
JSmith
2nd page mate.
"To evaluate the potential of Yamaha's NX-N500, I first had to gauge the quality of available source signals. The NX-N500 was discriminating enough to explore different inputs and resolution settings. Not all were created equal. From the start, the merits of higher resolution files was readily apparent. The best results came from the wired connection to the music server. This produced superior detail, dynamics and soundstage from local files and Tidal streaming. Wyred designed a clean circuit and it showed all the way down the playback chain. A close second was the wireless connection from the server. This gave up a small amount on all fronts, most noticeably as some dynamic compression. Third was Apple Airplay, tailored to be more forgiving. It was guilty of greater compression on dynamics and depth and additionally compromised on transient behaviour by dulling leading edges and prematurely truncating trailing edges. It remained pleasant but obviously lost information by direct comparison. Bluetooth was still a little further back in the pack but remains a decent alternative for those without access to better. These results were achieved using the highest quality resolution settings that the various programs would allow. If you opt for lower settings, expect inferior results."
Airplay being inferior makes sense because that is apple's bespoke format which from what I know converts/compresses to its own format.
Firefly00
New Zealand
2nd page mate.
Not seeing much in the way of measurements to back that up…
voodooless
Netherlands
Airplay is lossless, just limited to 24 bit, 48 kHz. So anything within these limits should be bit perfect.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
That's silly...
Firefly00
New Zealand
It’s probably the easiest and most convenient way to get lossless out of an iPad, which is depressing. Airport express costs less than a CCK, and doesn’t have wires. Only drawback is not getting that sweet sweet inaudible upgrade from 96 or 192kHz.
jammer
I've read alot of forums over the years but this one takes the cake for THE MOST speculative collection of opinions I've ever seen. I can tell you having been in hifi for over 20 years I wasn't a believer until I bought some servers into my system and listened. From a MacMini, to a Nucleus, all the way up to the higher end stuff like Antipodes and Pin Faun. They make a PROFOUND difference. I was completely blown away with what it did to my DAC (MSB), and how much better everything sounded.
You can have all the fun you want speculating and rationalizing and poking fun at those who are willing to spend the high price for these things but until you listen and test for yourself (with an ear, not a measurement) its just that, fun (for you) and speculative opinion.
PatentLawyer
Deep in the Soundstage
Nope.
PatentLawyer
jammer
I am actually. And I don’t get paid by the word.
Good to know, I can't believe you get paid at all quite honestly.. and thank you for proving my point with a complete lack of any rebuttal or experience with a product you have magically formulated such a staunch opinion on.
BDWoody
Chief Cat Herder
Moderator
Welcome.
Uh huh...
PatentLawyer
Enough ad hominem. Defend your point with reliable data.
_thelaughingman
Did you quantitate the difference in sound via measurements? Speculation based on subjectivity is what I am hearing in this post. Take your paid drivel to a garbage dump where it'll have some critters to listen to.
jammer
I actually own (or have owned) the equipment. Have you even listened to it? Data is only useful for the design stage not the end result of what your brain processes. You have data for my brain you can point me to? Your brain is the end recipient so data means almost nothing to most actual audiophiles.
You are trying to make sense, using data, of something we don't completely understand and can NOT measure. You can take your data...Listen to the device, properly set up and then come back and respond. Until then, your measurements don't make you correct.
Robin L
1 mile east of Sleater Kinney Rd
I guess you should know a little bit about what you just stepped in.
The founder of Audio Science Review, Amir Majidimehr, has deep background in audio and electronics, particularly the correlation between the measurable and the perceivable. This link offers up his curriculum vitae:
To the point: until meaningful and repeatable data is offered, subjective analysis is dismissed as not proven. So, your opening statement tells everybody in the forum who has been paying attention, including a great many audio professionals and others familiar with the inner workings of electronics and sound, that you simply cannot not be taken seriously.
Killingbeans
Right back at ya:
