I bought both the 7Hz x Crinacle Zero:2 and the Truthear x Crinacle Zero:RED following reviews from Audio Science Review.
In particular I was interested in the very low distortion, so as to be able to equalize the earphones in an optimal way.
After trying both, it seems to me that there is something that doesn't work as expected.
If you try to listen to sinewaves from 30Hz to 12Hz, the intensity of the perceived sound drops (naturally, particularly
if the signal intensity is not high), but you begin to hear other noises that are not compatible with the measurements
of distortion shown by ASR tests.
These are higher frequency disturbances (harmonics?) that resemble venting air.
I tried changing the pads, inserting them into the ear canal with greater force,
keeping them pressed in the ears, but the noises remain.
I tried several samples of the Zero:RED and Zero:2 and I asked my friends to try them to rule out a personal hearing problem: everyone hears the same noises.
I therefore tried with the Sennheiser CX 1.00, the Sennheiser CX 2.00g and the Audio-Technica ATH-M50x which
Inner Fidelity measured some time ago, reporting low distortion levels of up to 100dBA and these noises cannot be heard.
For the test I used some PCs and:
- SMSL DO100+Topping L30ii
- SMSL C200
- Topping E30+L30
- Topping D10s+Sabay A10h
- TempoTec Sonata HD Pro
- Hidizs S8
- E1DA #9038SG3
- E1DA #9038D
- balanced and unbalanced cables
Always the same result.
As signal generators I used RTA -> Signal Generator (Ymec DSSF3 from
http://www.ymec.com/products/dssf3e/ that is free
for the signal generator module).
Can anyone do the same tests and let me know if the same thing happens to them?
(P.S: sorry for my bad English...)
