No. Not used. Modules that were purchased and not used for whatever reason.AVS Forums? Did you mean used stuff?
Not the Audiophonics directly, but a bare NC252MP was measured in a multi-channel Buckeye amp below, so should be similar.Are there measurements of the siimilar-sized Audiophonics amp based on Hypex Ncore NC252MP?
https://www.audiosciencereview.com/forum/index.php?threads/buckeye-6-channel-amplifier-review.18579/
He adjusted the gain for 29 dB which is what he measures all amps at.Hi, Amir You forgot to turn the gain to full. It's not a fixed amp, as you can see. You must manually set gain to max if you're gonna stresstest it as a power amp.
I double checked with manual and Xtz. Youre measurements doesn't corolate to others.
Seems way to expensive for what it is.
My thoughts exactlyIs that really fair? There are tons of power amplifiers out there which measure even worse than this, but cost ten times as much.
On the flip side, are there really that many power amplifiers that are cheaper and better?
Thanks!
