This thread has been a great read, thanks for all the contributions so far. I just ordered a TA-20, so I'm excited to try out my first tube amp.
Quick question for all of those that are 'tube rolling', is it even worth trying and using the stock tubes, or should I look at upgrades immediately? I'm looking for a nice tube sound, I already have nice accurate amps, so looking for the tub experience really.
I've read through some of the purchases, but I'm looking for something that's on the cheaper side, but something that sounds tube like, or gives that nice tube distortion. I'm always on a budget, so if there are tubes you guys have tried that you like the best, please let me know.
Yes! The Shugaung "China 12AU7" stock tubes are sweet, quiet, no IEM hiss, and sound great.
The stock tubes sound to me like the JJ Electonic ECC822 12AU7 newly manufactured tubes, with the JJ's sounding a bit better - but the JJ ECC82's I bought are the Gold Pin version while the stock tubes are corrodable steel pins. Initially not a big (any?) difference, but over time tubes with Gold Pins won't corrode as badly and will cause fewer intermittency issues - you can always pull the tubes and scrub the pins. It also helps if the socket contacts are gold plated, but the TA-20's aren't.
The JJ Electronic ECC802 ECC82's I got from TubeDepot, but they are available from many places. I picked TubeDepot as they can be asked to cull the tubes for noise, gain, and provide triode internal matching and gain pair matching, if you select all the services it overall doubles the price but I would recommend at least do the pair gain matching for the TA-20. For a single Triode 12AU7 model then the Triode internal matching would be my suggested option.
https://tubedepot.com/t/brands/jj-electronic-tesla
As far as budget, you could spread out the tube rolling over more time than we've used for the spinning of new tubes - use the stock tubes for as long as you like - which realistically could be a long long time, continue to read up on the other tubes, reviews, suppliers, etc - and when you are so inspired pick up a pair or two. I recommend 2-3 pair at a time only because it is disappointing when one of the pair doesn't work out and you are left waiting another week or two to find, pay for, and get shipped another suitable tube pair, at least I'm happy I had 2 other pair when the new PSVANE 12AU7-S Art Series Gain Matched Pair had 1 soft tube.
Also, when you get fed up with rolling, take a break and enjoy the music, if it gets frustrating or disappointing - as all things electronic can - keeping it fun and special by maintaining patience is foremost - live long and be happy with patience.
BTW, the Hifiman Ananda really sounds great on the TA-20, and uses a much lower volume setting than the HE6SE V2 - 60-65 rocking out vs 80-85, and not only sounds as good as the HE6SE V2 it sounds better in a different way - which is great as I was concerned the HE6SE V2 was going to ruin me for other headphones, seriously. But, the Ananda kicks it with Bass and really widens up the sound stage and adds a surrounding sound that other headphones don't have at all.
Xduoo has come out with less expensive hybrid headphone amps, and new models of their DAC/AMP hybrid's, so there is an even wider range of headphones amps to try with tubes.
Not all tube / hybrid amps use the 12AU7, so be sure to check up on the tube types the amp you like uses before buying, and if you are interested in tube rolling check into the availability of stock and variance is available for that tube and its equivalents.
Have fun
