@cursive - wow, that's great, looks like you've been having fun getting to know your TA-20
I posted the feedback from Xduoo as well, I guess you missed it, the TA-20 can take a maximum of 8v input.
I've been running the D90 MQA in DAC mode "flat out" maximum output since that feedback from Xduoo, no overdriven symptoms so far.
I went back and added another update to
my post so as to not confuse others.
Also, some more feedback from Xduo:
"Xduoo reply below 8V is all no problem. if it is above 8v, it will cause distortion." - [email protected]
The D90 MQA XLR at most outputs 4Vrms @ 0dBFS, so it won't overdrive the TA-20.
Glad you are having fun with your TA-20
Just got the amp in today, loving it so far, sounds good with my old HE-560 which are my hardest to drive headphones.. Perhaps this is a silly question, but it appears one tube glows more than the other? Is this anything to worry about?
I'm honestly not even sure if it's one tube per channel, or how the circuitry is setup.
Nothing to worry about - tubes have unique physical aspects unto themselves, some tubes are reported to "flash" when starting up - I haven't experienced this on the TA-20, but thought I should mention it.
That is why when I order a pair of tubes for the TA-20 I find a place that does testing, gain measuring - matching internally and externally - between the two tubes, and check and cull for noise - this culling of tubes greatly increases the chance you will get a good sounding balanced noise free experience when plugging the tubes into the TA-20.
I've found tubedepot.com, audiotubes.com, vivatubes.com, have treated me very well. I'll add others later as I am ready.
I'll update more later - 4 pairs of tubes to test, I'll list details later.
Right now I'm taking a break from the TA-20 and I am using my Topping A90 with some new headphones - HD660s, Hifiman Ananda, Hifiman HE6SE V2 - spoiler - I prefer the sound from the TA-20 on those headphones, but the A90 sounds great too
