hmscott
- Joined
- May 17, 2020
- Messages
- 604
- Likes
- 493
That's a nice sized pairing between those two units, the SMSL M500 looks like it fits right there alongside the TA-20, sizes pair nicely.
Also, the locally built Hungary cable looks solid - if not a bit expensive.
Have you put it all together? How does it perform? Have you picked up any other tubes to try in the TA-20?
IDK what the output of the M500 is on XLR, but as above I needed to reduce the drive from the D90 MQA XLR output by -9.0dB to be able to "turn up the volume" on the TA-20 without distortion. I have the D90 MQA set at -12.0dB right now, seems fine either way, I may go back to -9.0dB.
I did get a few more tidbits of feedback from Xduoo to my questions, specifically how they would rate each of the tubes they earlier listed as having been tested on the TA-20 by Xduoo:
As translated by Hifigo from Xduoo:
PSVANE 12AU7 这个管在人声方面会更好, ( better on vocal)
GOLD LION 12AU7 这个管在器乐方面表现会更好,( better on instruments)
Mullard 12AU7 这个管低频会更好一些, ( better on bass)
Google translate:
PSVANE 12AU7 This tube will be better in terms of vocal, (better on vocal)
GOLD LION 12AU7 This tube will perform better in instrumental music, (better on instruments)
Mullard 12AU7 this tube will have better low frequency, (better on bass)
I realized I should test the Matched Gain pairs of tubes I ordered in addition to the TA-20 to see if they were functional. Good thing I did test them as one pair - the PSVANE 12AU7-S Art Series pair had a bad tube - very low gain. Easy to notice, I swapped tube socket positions to see if the low gain moved with the tube, and it did. So I've started the Amazon return.
The PSVANE 12AU7-T MKII tubes are both strong and do indeed have a vocal forward presentation, so much so I'd recommend them to anyone that has trouble hearing the vocals in videos, TV, etc. I can turn down the volume to 30 and the voices stand out all the way down.
The normal volume setting I'm using on Youtube is 52 for voice centered media. The movie streaming services don't have as much drive and need to have the volume turned up to 65. For movies, I turn up the sound a bit higher than voice media to enjoy the dynamics of the presentation. Again, the top volume setting on the TA-20 is 95.
I haven't done much music testing yet, the tubes are fresh out of the box and tubes have already been rotated through several pairings, and it has hardly been 18 hours since I unboxed and set up the TA-20. More later.
Update: Something else I noticed, TA-20 China labeled "generic" tubes are printed with the same shade of Red and a similar font to the PSVANE tubes listed here:
https://www.aliexpress.com/item/1005001745244020.html
I've asked Xduoo via Hifigo.
Google translate:
