i duooAs long as you run that shiit ballanced, it's a fine amp.
yes i meant the Magnius. Thanks for catching the error.The Modius is a DAC, did you mean the Magnius?
https://www.schiit.com/products/magnius
Easy to mix up those names
What the heck is a Magnius? That doesn’t sound Norse.
It’s like Modius. When we were developing a bigger, better, balanced Modi, we started jokingly calling it “Modius Maximus.” The name stuck. So when we also started working on a bigger, better, balanced Magni Heresy, we started calling it “Magnius.” That name stuck too. So now you’re stuck with Modius and Magnius.
But you’re conflating Norse mythology with Roman terminology!
Right.
But that doesn’t make sense!
Dude, you used the word “conflating.”
Sigh. Okay. Fine. I guess that’s all we should expect from a company that gets all its Norse mythological information from comic books.
And Wikipedia. Don’t forget Wikipedia!
The Magnius measurements and spec's look good, how does the audio drive compare to the TA-20? What is the impedance for your
headphones? And, which DAC do you use?
Balanced Headphone Output:
Maximum Power, 16 ohms: 6.0W RMS per channel
Maximum Power, 32 ohms: 5.0W RMS per channel
Maximum Power, 50 ohms: 3.2W RMS per channel
Maximum Power, 300 ohms: 1000mW RMS per channel
Maximum Power, 600 ohms: 500mW RMS per channel
Single-Ended Headphone Output:
Maximum Power, 16 ohms: 2.2W RMS per channel
Maximum Power, 32 ohms: 2.0W RMS per channel
Maximum Power, 50 ohms: 1.3W RMS per channel
Maximum Power, 300 ohms: 300mW RMS per channel
Maximum Power, 600 ohms: 150mW RMS per channel
Note: Maximum power rated at 1% THD, high gain
THD+N:
Low Gain, Balanced Output: Less than 0.0001% (-119dB) at 4V RMS into 32 ohms
High Gain, Balanced Output: Less than 0.0003% (-110dB) at 4V RMS into 32 ohms
Low Gain, SE Output: Less than 0.003% (-90dB) at 1V RMS into 32 ohms
High Gain, SE Output: Less than 0.004% (-87db) at 2V RMS into 32 ohms
IMD:
Low Gain, Balanced Output: Less than -112dB at 4V RMS into 32 ohms, CCIF
High Gain, Balanced Output: Less than -110dB at 4V RMS into 32 ohms, CCIF
Low Gain, SE Output: Less than -73dB at 1V RMS into 32 ohms, CCIF
High Gain, SE Output: Less than -72dB at 2V RMS into 32 ohms, CCIF
SNR:
Low Gain, Balanced Output: Greater than 125dB, unweighted, referenced to 4V RMS
High Gain, Balanced Output: Greater than 115dB, unweighted, referenced to 4V RMS
Low Gain, SE Output: Greater than 105dB, unweighted, referenced to 1V RMS
High Gain, SE Output: Greater than 110dB, unweighted, referenced to 2V RMS
Crosstalk:
Less than -90dB, 20 Hz-20 kHz, either gain, 300 ohm load
Less than -70dB, 20 Hz-20 kHz, either gain, 32 ohm load
Output Impedance: Less than 0.1 ohms at either gain
Input Impedance: 50k ohms
Gain:
Balanced Output: 1 (0db) or 5 (14db)
Single-ended Output: 0.5 (-6dB) or 2.5 (8db)
Topology: Composite amplifier with OPA1688 input buffers, LME49724 differential amplifier, TPA6120A2 current feedback output stage, DC coupled.
Protection: Standard failsafe DC power input and muting relay
Power Supply: “Wall wart” style 24VA 15VAC transformer, linear regulated +/- 13.5V rails with over 6,000uF filter capacitance
Power Consumption: 6W idle, 21W max
Size: 9 x 6 x 1.5”
Weight: 2 lb
APx555 Report for Magnius
So far the PSVANE 12AU7-T MKII sound best for vocals - I really enjoyed listening to spoken content on them.Going back to the PSVANE to see if i get some hours on them the microphonics will disappear.
Well, so far the cost of the tubes isn't as much as it could be, as there are NOS tubes out there for $hundreds$ more for one pair, IDK if that will help audibly, perhaps it's more of a "tube collectors" hobby than audiophile related.Well i've finished tube swapping and checking and doing shit... JJ tubes, best tubes
Stock tubes have very good sound for free tubes (and 8 bucks a pop aftermarket) - but there is a lot of variance.
12AT7 from JJ are a ton less noisier and have better gain than 99% of 12AU7 tubes out there.
Overall the JJ tubes i got better bass, more resonance for certain instruments and accurate highs. I have not heard anything going on in the mids with them.
The PSVANE's i got are all microphonic... other than that they are alright. They seem to suck out all the bass enjoyment out of the music though (makes bass more accurate and fast but less punchy) ... especially with the HD800.
Mullards i got have ~bass, bit bloaty honestly. They mostly cater to mids lovers - vocal stuff is a tad better, but the difference from them on the TA20 and my A90 is quite minimal.
In my opinion - to get better tubes you need to spend a ton more money, so you know ... don't.
In my limited experience tubes have so much variance that it is just not worth experimenting that much because all you do is throwing money away. I got 6 JJ tubes and only have 1 dud with the 12AU7's having no noise whatsoever and only the 12AT7 having an audible noise floor.
This has been an interesting experiment ... a fairly costly one - but informative. If i did not have the HD800/DT880 i would not buy a tube amp again.
I'm sticking with JJ tubes.
Just my 2 cents, you do your math.
@hmscott i used to test with KZ ASX, but gave them to a friend. I'm now testing with my IKKO OH10 as it appears to have the same sensitivity as the KZ.
Edit: on a side note - the tube sockets on the TA-20 are starting to show wear and the amp is giving me protection errors when seating tubes from time to time... and it's not been more than 50 swaps yet. Take that as you will.
Which JJ model is your recommendation? Do you think the extra gain of the 12AT7 JJ tube is worth the higher noise floor?
It looks like you bought 2 kinds of the same tube, the ECC802s, the Long Plate - those are supposed to have lower noise than the EC802, but different sound.I am content with either one of these:
https://www.tonefactory.nl/jj-12au7-ecc802s-e82cc-balanced
https://www.tonefactory.nl/jj-12au7-ecc802s-gold-pin-balanced
They are essentially the same tubes but the gold pins are allegedly lower noise and tighter tolerances.
I've noticed that same phenomenon with my fast tube swapping too. I find the sound mellows after a few hours of running, gradually getting better sound the longer they run. I hear the same in the comments about the JJ tubes, from multiple sources. "I gave it a few minutes to warm up and the sound wasn't good", others say "after a few hours of warming up it sounded better and kept sounding better the longer it ran"To whomever finds these ramblings upon further swapping the JJ's to Mullard/Tungsol/Sylvania/EH/PSVANE:
There appear to be a-lot more energy somewhere in the 6k-10k register with the JJ's - In most cases that is not an issue, but you will come across songs where if you are using them with an HD800(S), there will be pain.
Yes!!, that is exactly the synergy I heard when I put in the JJ ECC802S tubes and plugged in the Sennheiser 598cs, the change in the sound coming out of the 598cs is simply "magical". Thank you for sharing your moment of discovery.I learned the hard way that xDuoo TA-20 requires a very good source to sound it's best. I used to feed it from SMSL SU-8 and FiiO Q5s. Not bad, and I was audio happy. But then I bought SMSL SU-9. The new sound hit me as a ton of bricks. I was mesmerized. Finally I glimpsed into what 'audiophile' means. Basically it's a non-stop audiogasm. I am not being sarcastic and I am not kidding. That has been my experience. YMMV.
Where did you find the 5814A NOS tubes? Link? Thank you!My rig:View attachment 106509
SMSL SU-9 -> xDuoo TA-2 -> Monoprice M1060c Open Mod
Tubes: Philips 5814A Blue Label Matching 12au7a NOS USA Tv7 Tested
ebay...
I have Tin P1, T2 and blon 03, tried them with tubes, didn't like the sound. No noise though, at least with a 4.4 balanced cable, didn't try SE.Do you have any IEMs that you could listen to on the TA-20 with 5814a tubes? It may be some IEMs are ok on NOS tubes, while others are sensitive enough to pick up the noise. And, some tubes might be noisy with many IEM's too.
Nothing better than a test.I have discussed with a couple of NOS tube providers about adding a test with an IEM to the list of acceptance tests - at least for the tubes that I want to purchase. I might need to send them an IEM for the testing.
I have:What other tubes have you tried?, and plan to try next?
Your description matches closely the Philips 5814A sound. I'm reluctant to recommend them at this price though ($49.19). I bought them in 2019 for $28.... I search something like a spacious (3D), and a nice banging, like to get more, but tight bass with fast impact. ( I'm not a basshead, but i like it if its done right)
