WolfX700 Measurement of SMSL Sanskrit 10th AK4493 Edition
ichonderoga
Thx for this @WolfX-700. I’ve just ordered one :)
SMSL-Mandy
Zek
But there is no visible indication that this is a Mk II model?
Tks
Now I'm wondering how optical performs.
Regardless, for this price, this is an awesome purchase. Great job @SMSL-Mandy to you and everyone back in the workplace. Great improvement over the original.
I would look for mention of it using AK4493 in the advertising at least to indicate it is the second version.
kouki_monster
Is it possible that optical is not ok? I would be purchasing for optical use only...
Tks
If I had to put my money on it, I'd wager it's surly better than Coax. Seems Coaxial has been a lingering thing that doesn't get much use or attention these days (I sure never used one in my life, then again I never took audio serious before the downloadable music era, so I never used CD players and such).
For the price, I doubt you'd do yourself a disservice and try it out. Regardless of how it goes, you still got pretty much the best bang for buck desktop DAC currently I'd say (and more than enough USB input users that wouldn't mind having it in case you end up not liking it).
ichonderoga
@Zek just got mine and nothing besides the V2-sticker on the front sets it apart physically. So I would also be looking for AKM4493, MKII or V2 when searching/ordering and crossing my fingers that they send the right hardware.
odyo
Considering the unusually cheap price, I will buy a secret one of my friends for quality tracking after it is officially launched.
This dacs looks too good to be true lol. Did you bought the secret unit ? I'm curious about it.
N
nhatlam96
Guest
Hello, noob question here.
Coax has 109db and usb has 113db. Why does coax has 4db less than usb? Is it due to the added jitter?
Amir said that toslink is a bit better than coax, so toslink would be around 110db then?
Veri
USB implementation in this device is simply much better. Probably, the receiver for coax/jitter is a mediocre one. 109dB still isn't "bad" by any means, though.
Reactions: PSO
N
nhatlam96
Guest
No, it's not^^ I just wanted to understand if the jitter decreases the thd+n value. Does the thd+n also account for multitone?
Veri
It's likely to have a similar, small effect, yes. That 3dB drop in SINAD is less than 5% of a setback though, I'm sure it's fine.
hawk01
south of the equator!
this is great, but i'm stuck with a copy of the old version (not that i use it...)
keep in mind that the volume control on the 4493 is, afaik, lossy, so you need a preamp
@SMSL-Mandy any chance of an upgrade discount or replacement? i'd like to use the new version in my portable rig.
i was hoping to use the sanskrit dac directly connected to power amp without preamp since it has digital volume control. i read that properly designed digital volume control is better than analog which is common to preamps. is the sanskrti volume control really lossy? lossy meaning 16-bit is degraded when you reduce volume?
N
nhatlam96
Guest
jitter is timing error in digital devices. the frequency change here is so rapid, that it manifests as noise, which decreases the sinad score slightly.
