Yeah lockdown did put things on hold for a long time now. But you have good reference how the real thing sounds like if you go 3-4 times a week to concerts. I'm sure you enjoy these speakers a lot. A 5,5"woofer is what it is. This one gives a lot of base for it size and will give many 6,5"drivers run for their money. Did you change the resistors for the treble? Or use the standard ones?
Change the resistors?
I don't want to reproduce a large Steinway or Bosendorfer in my home, let alone a full orchestra. Opera? We go every month or two, have Nabucco booked for a couple of weeks time, but never listened to a note at home. Hear Theolonious Monk at home almost every week, but never live. If I liked a lot of rock music, I'd probably only use headphones.
I get that studio monitors are designed to provide engineers with accurate sound reproduction over a wide frequency band up to high sound levels in largely damped rooms with little or no care for aesthetics, and are sometimes adapted for consumers by application of wood veneer, but that's not what I want at all. My speakers suit my preferences, just as anyone else makes choices based on their preferences. I don't need speakers that can play heavy rock to 20Hz and 105db as I don't listen to it.
It doesn't bother me that a chunk of the cost of the speakers is of largely aesthetic value. We could have furnished our music room from IKEA, lots of Kallax for records and a fisherman's chair (very cheap and comfortable), but we spent a lot more on furnishings than we did on the Wilson speakers.
I also have a spatial audio system in my house, currently 6 speakers in my music room, 16 in the main living room, more upstairs. They are very high quality, I usually use Amazon HD or Airplay (built in) or from Innuos by uPnP and they have very clever DSP. Being able to fill a room with immersive sound is often far more satisfying than good two channel sound, which gives me a lot of hope for Dolby Atmos. There has been a lot of work done on spatial audio in recent years, but the system I use works because you can now get fairly cheap hardware to send 24/192 PCM data to an almost unlimited number of wireless speakers (I use four wired Ubiquiti access points) without connection issues.
