Yes, that.Probably a typo where he meant 1 amp/driver.
I've got a single Altec 603B here that's probably 70 years old.Classic speakers overwhelmingly came with passive crossovers, but I've never seen any data on longevity of things like the drivers. I'm inclined to believe that speaker manufacturers didn't really give a lot of thought to time-to-failure, and were more concerned with just making good quality speakers for their price range. I certainly know this was the case when I worked at Altec Lansing, and I know that well taken care of examples lasted a long time (mine are still performing as good as they ever did). I've had more troubles with foam surrounds on JBL woofers, but that is easily cured. I've never had a passive crossover fail.
That's been my experience as well. Shortly before I left Altec (when they were in Anaheim), I scored a bottle of the clear 'goop' that they used to dope the cloth surrounds of their woofers like the 416 because I thought that this was going to be a wear item which would need refreshing at some distant point in the future. As it turns out, I've never had to open that bottle of goop.I've got a single Altec 603B here that's probably 70 years old.
My 604Bs are from the early 1950s, so they're pushin' 70 as well.
Makes no sense to me and it could be some 'ad hoc' rule-of-thumb...Sorry - meant 1 amp per drive unit. (See, another interchangable term pair - speaker/drive unit)
I can't help thinking we're at cross purposes. This is what (and all) I'm talking about...Makes no sense to me and it could be some 'ad hoc' rule-of-thumb...
So for any given "active" speaker, the designer would be a fool to use anything but an efficient pwm or high voltage DC input wall-warts, or high-Z speakers, etc.
That's 'cause they over-gooped -- at least judging by the runny goop that one sees more than occasionally on Altec driver surrounds of a certain age.That's been my experience as well. Shortly before I left Altec (when they were in Anaheim), I scored a bottle of the clear 'goop' that they used to dope the cloth surrounds of their woofers like the 416 because I thought that this was going to be a wear item which would need refreshing at some distant point in the future. As it turns out, I've never had to open that bottle of goop.
I don't understand that type of goop, but will raise you over 200 flavors of Silicone in combined catalogs of GE+DOW alone.Gwyneth Paltrow's goop
I've found that the goop does indeed run (The Altec goop, not Gwyneth's) and I have to rotate the woofers 180 degrees once a year or so it doesn't run down to the cone.That's 'cause they over-gooped -- at least judging by the runny goop that one sees more than occasionally on Altec driver surrounds of a certain age.
PS Do NOT get your Altec goop mixed up with Gwyneth Paltrow's goop.
Looks like that dome took a bullet hit.(ever so slightly) Less off-topic The JBL "Lansalloy" surrounds, at this late date, seem to cause/be much more trouble than anything I've encountered from Altec.
Here's my bottle of Most Excellent Official Altec Lansing VIntage Speaker Surround Goop. Appears to still be 'goopy' after all these years. Probably goopier than me at this juncture.
Nope, but come to think of it I wasn't the one who filled the bottle of "speaker goop" - someone filled it for me. Now I'm all paranoid about opening it to check. Its very thick - is that what urine does after 40 years? Ugh, this is getting disgusting.Are you a long distance truck driver?
try crowd-sourcing some funds for a brand new bottle... even if you aim to retain the melted snow!Nope, but come to think of it I wasn't the one who filled the bottle of "speaker goop" - someone filled it for me. Now I'm all paranoid about opening it to check. Its very thick - is that what urine does after 40 years? Ugh, this is getting disgusting.
Yes!quote:
I design passive xo speakers, self powered speakers and speakers with one or more separate rack mount amplifiers.
A misconception about passive crossovers is that they are inefficient / lossy.
They can be if there is a lot of current passing through resistors but the reactive parts normally have small losses.
Best
Tom
Hey... I mean... I found a pair of LE-8s (or maybe LE-8As) at the dump. That is the worse-looking of the two, as found.(ever so slightly) Less off-topic The JBL "Lansalloy" surrounds, at this late date, seem to cause/be much more trouble than anything I've encountered from Altec.
The 'operative word' here being the subjective 'good'?That's why good active designs have limiters and thermal cutouts for driver protection.
So far I haven't heard a SONOS or Bluetooth speaker that I would bring home to listen to. Not saying that I won't but...mostly bought by folks who like music but often arent as discerning as we up in here.
I presume that you meant the acronym: FUBAR (FU BAR)? (the acronym SNAFU [SNA FU]) might also be fitting.It can be done manually in "BB code" mode by using "LIST=1":
Code:[LIST=1] [*]foo [*]bar [/LIST]
- foo
- bar
I understood it as you state here. Perhaps because I have a wife who has a third-eighth grade level of English & have to interpolate a lot of things.Sorry - meant 1 amp per drive unit. (See, another interchangable term pair - speaker/drive unit)
