- Thread Starter
- #381
I have already bought the PreSonus Eris E5 XT. Is that one the smaller version or something?I would like to see the Presonus Eris 3.5 getting reviewed.
By the way, could you measure (or maybe mention in the listening test) any kind of residual self-noise/hiss at 1m? Since most of these are made to be used in a near-field situation, this really makes sense.I have already bought the PreSonus Eris E5 XT. Is that one the smaller version or something?
Didn’t he say he only gets like 50dB of range? These hisses are usually >70dB down.By the way, could you measure (or maybe mention in the listening test) any kind of residual self-noise/hiss at 1m? Since most of these are made to be used in a near-field situation, this really makes sense.
Well, I meant with a measurement mic. Since I think it's already used to calibrate the volume, it shouldn't be too much effort. Either way, I'm sure this is something A LOT of people want to see; because a great monitor might be rendered completely unwanted by hiss.Didn’t he say he only gets like 50dB of range? These hisses are usually >70dB down.
Should‘ve also bought the $20 cheaper non-XT model (looks like only difference is the XT has a waveguide) to compare.I have already bought the PreSonus Eris E5 XT. Is that one the smaller version or something?
My guess is that these are the modern version of the truly execrable (IMO) NS-A635(A) (a/k/a its Radio Shack morph, the Optimus STS-100*). Truly horrible loudspeakers (and I have a pretty low bar for cheap/free loudspeakers... my pair were dump finds, as was the CR-220 in the photo below). The crossover consists of two NP electrolytics (one for the MR, one for the tweeter) -- which likely doesn't help.A 3-way Acoustic Suspension design for $130/pair:
Yamaha NS-6490 3-Way Bookshelf Speakers Finish (Pair) Black https://www.amazon.com/dp/B00018Q4GA/
'Manual' attached for more detail.
Another one making the rounds on various AV forums is DCM TP160S. A lot of praises sang there, comparing them to much more expensive speakers.Another high priority recommendation IMO should be the Chane A2.4. This has been an internet darling for several years with a religious like following in frequency of recommendations, but AFAIK no one has done real measurements of any of their models.
Elac b6 would be good, I would like to see what all the fuss is about.
Ahh, that's right. Sorry.I believe he means the original b6. They were a big deal for a couple years when they first started showing up at their price point.
Fig.3 Elac Debut B6, anechoic response on tweeter axis at 50", averaged across 30° horizontal window and corrected for microphone response, with nearfield responses of woofer (blue), port (red), and their complex sum (black), respectively plotted below 300Hz, 850Hz, and 300Hz.
The top octave rolls off a little earlier than usual, and coupled with the fact that the B6's lateral dispersion narrows significantly above 7kHz (fig.5), the Elac might sound lacking in top-octave air in medium-to-large rooms or in rooms that are heavily furnished. Herb's listening room is both small and relatively undamped, which is probably why he was not concerned by the speaker's somewhat muted anechoic output in the high treble. In the vertical plane (fig.6), a sharply defined suckout in the crossover region develops more than 15° above and 10° below the tweeter axis.
An interesting thing is a lot of reviews claimed they were a clear step up over the Pioneer SP-BS22-LR, particularly in the treble. Since the Pioneers measured so well on the Klippel, I'm really curious what the B6 spin will look like. There's also bound to be a ton of B6's out there due to their popularity and supposed price point shattering performance of the time.Ahh, that's right. Sorry.
I've actually never heard the original morph -- they had a reputation for being rolled off in the treble, if memory serves(?)
EDIT: Heh, just (re) read the Stereophile review of the B6.
As Dan Quayle once said, "It's a terrible thing to lose one's mind"
Here's the FR data from the above mentioned review
https://www.stereophile.com/content/elac-debut-b6-loudspeaker
I'll let JA speak for himself
That would be really interesting indeed, especially with some B2031As to compare them with. (Certainly someone would have a pair of those kicking around? Over here they're just about the cheapest 8" active monitors you can buy, at sub-€300 a pair. Save for some hiss that isn't much of an issue at typical distances and a dubious bass response, they seem to be hard to beat.)Ah, I used to have a Genelec 1031A. Gave it to my son to use in his room many years ago. I can ask him next time he comes over so I can measure it.
Ah, didn't realize PSB had gone so low in price. Bought the P5 on Amazon. Given their NRC research tradition, hopefully it won't be a terrible speaker I get stuck with!A vote for the PSB Alpha Series - the Alpha P5 and the Alpha P3. P5 reviewed here: https://www.stereophile.com/content/psb-alpha-p5-loudspeaker
