VTV Purifi Amplifier With SIL 994EnH-Ticha Pro Buffer Review
This is a review and detailed measurements of the VTV Purifi class D amplifier with SIL 994EnH-Ticha Pro Opamp buffer stage (one of the options). It is on kind loan from a member and costs US $1,845 in this configuration.
It was love at first sight when I saw this rack mounted case with handles:
VTV Purifi Amplifier with Sonic Imagery Labs 990EnH-Ticha Pro Opamp review.jpg
Yes, the amp is light so the handles are really not needed but it is cool nevertheless. :) Speaking of cool, the amplifier never warmed up in any of my tests.
Typical of this class of amplifier, only balanced XLR inputs are provided:
VTV Purifi Amplifier with Sonic Imagery Labs 990EnH-Ticha Pro Opamp back panel balanced review.jpg
There is an option for SpeakOn speaker terminals.
We already know the measurements of the Purifi amplifier Reference Design. Question is whether the assembly and choice of SIL op-amp has an impact on the measured performance.
NOTE: I mistakenly labels the original review and graphs as 990Enh. It is actually 994Enh.
VTV Purifi Amplifier with SIL Buffer Measurements
As usual we start with our 5 watt dashboard into 4 ohm load:
VTV Purifi Amplifier with Sonic Imagery Labs 990EnH-Ticha Pro Opamp Measurements.png
Gosh, that ugliness in the FFT spectrum really makes you lose your appetite coming from squeaky clean reference design:
The noise is triggered by the power supply. Whether op-amp is the source of the power supply or combination of both is hard to say. What is not hard to say is that we have lost some performance which also shows up in SNR:
VTV Purifi Amplifier with Sonic Imagery Labs 990EnH-Ticha Pro Opamp SNR Measurements.png
Fortunately performance is still superb in grand scheme of things:
Crosstalk thankfully is as excellent as the reference design:
VTV Purifi Amplifier with Sonic Imagery Labs 990EnH-Ticha Pro Opamp Crosstalk Measurements.png
Frequency response however is truncated a bit:
VTV Purifi Amplifier with Sonic Imagery Labs 990EnH-Ticha Pro Opamp Frequency Response Measure...png
Power levels are the same as reference:
VTV Purifi Amplifier with Sonic Imagery Labs 990EnH-Ticha Pro Opamp Poer into 4 ohm Measurements.png
VTV Purifi Amplifier with Sonic Imagery Labs 990EnH-Ticha Pro Opamp Poer into 8 ohm Measurements.png
I did not run the peak and max power at the time of the original review so we have some new data points:
VTV Purifi Amplifier with Sonic Imagery Labs 990EnH-Ticha Pro Opamp Max and Peak Poer into 4 o...png
As well as this test for frequency sensitivity:
VTV Purifi Amplifier with Sonic Imagery Labs 990EnH-Ticha Pro Opamp Power into 4 ohm vs freque...png
I will have to run this on Purifi reference at some point to see how it did. I am thinking the buffer is messing this up right now.
Finally, multitone test which clearly shows power supply related spikes:
VTV Purifi Amplifier with Sonic Imagery Labs 990EnH-Ticha Pro Opamp Multitone Measurements.png
VTV had me happy with its case work. Alas, the buffer as chosen appears to drag the pristine performance Purifi module down. Despite that, overall excellence of Purifi engineering still shows, allowing this amp to still outperform some 140 amplifiers tested to date!
I can't recommend the VTV with the buffer as chosen. Hopefully other variations don't leave performance on the table this way.
Edit: see the teardown here: https://www.audiosciencereview.com/...er-teardown-sil-990enh-ticha-pro-opamp.24861/
My daily routine is to eat dinner and then go to the garden and work and work and work. Come back in all sweaty. Clean up and then do reviews like you see. It is a very strenuous routine than makes me wonder why I do it. Then I see a cucumber like this in the greenhouse and it makes it all (almost) worthwhile!
Can't find stuff like this in the grocery story. Letting it grown for a couple more days before eating it!
Feyire
Netherlands
Could you show us images of the inside? I'm curious to see the power supply position and orientation.
Yes, I have permission to do that. It is past midnight though so will do tomorrow...
martijn86
The Netherlands
When am I supposed to read all these reviews! No honestly, I love all your hard work. This is all invaluable data for making well thought out purchase decisions. Thanks Amir!
Phorize
U.K
This is a review and detailed measurements of the VTV Purifi class D amplifier with SIL 990EnH-Ticha Pro Opamp buffer stage (one of the options). It is on kind loan from a member and costs US $1,845 in this configuration.
There we have it, the difference between product engineering and stuffing components into a box and calling it a day.
abdo123
Brussels, Belgium
how can someone mess such a straight forward design?
The 'reference' design literally looked like anyone can do it with access to documentation from Purifi.
the THD+N frequency dependency is just nasty, the whole point behind buying a 2000$ Purifi amp is to have Class D power that does not exhibit such behavior.
Tks
A bit off topic, but it's just funny to see how long Benchmark holds a visually distinct lead in the SINAD chart over other power amps. Half decade now, and still nothing in sight..
@JohnYang1997 You guys still have your sights set on that crown?
Lol btw, what is that panther
jae
At 100W, but I feel there's no real reason to prefer the benchmark over purifi for SINAD alone if you're using 180-220W+ @ 4 ohm, especially at almost double the price or more (assuming reference design and their own specsheet).
Jim Matthews
Taxachusetts
A garden tour, please.
(While everything is in bloom. Set to the theme music of your favorite Disney Princess as a plus...)
Matias
São Paulo, Brazil
pma
Prague
No. The analog buffer will never have such bad higher frequency distortion. It is a system or amplifier wiring topology issue. These companies are a mere assemblers without deeper insight. It is a shame where the audio has ended.
Matias
São Paulo, Brazil
Agreed. When their only job is assembling modules in a box, the least they should do is measure the end result to see if they routed everything properly.
Koeitje
Count Arthur
Except the Purifi outperforms the NC400 in all areas but SINAD at 1KHz/5W/4Ohms. ;)
Fair point, and I imagine you'd have a hard time hearing much difference between any of the Hypex and Purifi amps clustered at the top of the list. However, I think the NC400 is significantly cheaper than the Purfi modules, which would make it the best value for money - possibly. :)
