I have just read all of Uptone’s blurb about the EtherRegen. Incredibly, nowhere do they actually say what it does
Hold on, I will read it again thoroughly
“6-layer circuit board…… a significant reduction in upstream phase-noise fingerprint………active, high-speed, low-jitter differential digital isolator chips……ultra-low jitter differential re-clocking flip-flops”
nothing yet
“Active Differential Isolation Moat …………….eliminate the signal-borne phase-noise …………….The differential isolators prevent the data-borne clock signature from getting onto the ground-plane of the PCB”
must be soon
“two isolated data/power/clock domains ……..advanced, programmable, jitter-attenuating clock synthesizer with four differential outputs…………Special conversion buffers are positioned just millimeters from chips that require single-ended clock ………12 transformer cores in each port……. ground their center-taps through capacitors ……lowest-impedance integrated voltage regulators”
hold on
“X7R and X5R capacitors sized and selected by their derating curves. …… “
Well that explains it all, I will definitely get better audio using X7R and X5R capacitors sized and selected by their derating curves.
(This is where I lost the will to live)
A huge list of components and features supposed to impress me with nothing to explain the benefit of any feature
So somebody, please, in ten words or fewer, what does the EtherRegen do ? (other than switch)
