Unusual Speaker Designs
paddycrow
Grand Haven, MI
RDacoustic - "Evolution" + "Euphoria" speakers, for some more info, see #113
53241076_1917038921737901_620213197600718848_n-o4c5dv8omvkffj8djchul2g9ei5am22vhkmjql21a8.jpg
I wouldn't mind having that diffuser on the back wall.
Although, it looks like it would be a PITA to keep free of dust.
pozz
pozz
Слава Україні
Editor
pozz
pozz
Слава Україні
Editor
pozz
pozz
Слава Україні
Editor
Kal Rubinson
Industry Insider
NYC
I'm new to speakers, does "isobaric bass port" speakers count for this thread, or is it adopted by more manufacurers?
Wilson Benesch - Endeavour / Discovery II
There are other "isobaric" designs, e.g., Linn, but the others mount both drivers inside and facing out. I cannot think of a valid justification for this arrangement which exposes the driver to possible damage.
andreasmaaan
Theoretically, the less air between the diaphragms the better. And motor force and suspension asymmetries may be balanced out to some extent as a result of each diaphragm being in opposite motion to the other relative to its motor/suspension system.
Not sure how effective this would be in practice, but can see why, all else equal, such an arrangement would be optimal, in theory.
pozz
pozz
Слава Україні
Editor
Kal Rubinson
Industry Insider
NYC
Vladimir Filevski
Isobarik, meaning constant pressure. The two bass drivers move in phase, such that the pressure inside the box doesn't change.
https://en.wikipedia.org/wiki/Isobaric_loudspeaker
Invented by Harry Olsen in the 1950s so nothing new under the sun.
S.
Actually, pressure inside the box does change, but the pressure of the air enclosed between the two woofers membranes does not change. And yes, it is an old invention by genius Harry Olson. It cuts required box volume in half and lowers the second harmonic distortion.
Well, exposed back speaker frame is more sturdy than exposed fragile membrane facing out of the box. But ugly at worst... and "industrial look" at best.
sergeauckland
Suffolk UK
Actually, pressure inside the box does change, but the pressure between the two woofers membranes does not change. And yes, it is an old invention by genius Harry Olson. It cuts required box volume in half and lowers the second harmonic distortion.
Thanks for the correction. I meant the pressure in the box that's between the two woofers, not the box behind the first one which clearly has pressure changes. Should have been more specific as to which box!
S.
