STC
I am grateful for the description of the sound. This is important to know if the setting are correct. Here is what I observed using a non BACCH XTC.Bach Cantata BWV 91, Rudolf Lutz, J.S. Bach-Stiftung. Gelobut seist du, Jesu Christ
Speakers angle is about 21 degrees ( recently moved to accommodate rear Ambio). Speakers are 236cm from head. Mid point of the two speakers measurement.
Only the main speakers used. Source Apple Music via DAW to Motu 8A DAC.
With crosstalk cancellation - the width is about 60 degrees only which should be the same as stereo speakers placed at the conventional 60 degree triangle. Orchestra size sound with depth and separation. Female slightly towards the left, Male choir about 20 to 30 degrees to the right. Excellent separation of instruments. I am not hearing wide mouthed lady.
WITHOUT XTC- all sound jumbled in the 21 degree stage. Shallow depth typical of stereo playback.
Conclusion easily distinguishable.
With XTC - Voice is in the centre. AT 21 second he probably towards the right as the sound moved towards left of the speaker. Otherwise, it is in the centre. Piano sound is about 40 degrees width.Schubert Lieder - Ian Bostridge, track 3 "Auf der Donau" Op. 21 D.553 - minimal difference
Without XTC - The vocal is slightly fat/full. When you AB the vocal with XTC is more natural and correct. The vocal is more forward with stereo. Probably, typical stereo setup would give a bigger stage.
Beethoven Symphony No. 3 - Niklaus Harnoncourt
Not sure which track you used. I listened to Allegro com brio
With XTC - 60 degrees stage and depth. you get the usual separation and clarity with XTC.
Plain stereo playback - congested but with typical 60 degrees the stage should be somewhat similar except that the lack of depth and spatial feel.
Binaural - Physical Dreams:
With XTC - This is rich. Like listening to binaural, strangely the low rumble feels like coming from the rear. You feel it as if enveloping you.
Without XTC - still got good stage but I suspect this is not binaural made naturally but with effect.
Maybe a good recording to demo BACCH but I don’t think this is a true binaural recording.
Hans Zimmer - Blade Runner 204
Wow…. Thanks for the track. Love the rumble. looks like a 120 stage and the low bass is bigger compared to stereo. Like all of the above the difference is separation, more details and depth compared to stereo playback.
Rereading your observation of the tracks, I suspect you could be over cancelling. The proper way to do AB is to have 4 speakers. 2 for stereo playback and 2 for XTC. Only then you can easily tell the correct location.
Just a note for those interested in 3D sound. crosstalk cancellation should render the sound more natural. Correct setting supposed to sound always better than stereo except for some heavy centre rock music. The the SPL role matters more than soundstage.
As I have previously mentioned, make you own recordings if you are serious about getting it right. For first few years, I almost gave as the timbre was not correct because I was over cancelling thinking the stage should be 180 degrees for all recordings.
Best reference to know if you have done your setting correct or not is to compare Time (Pink Floyd) ,Hotel California, Black Magic Woman ( Patrica Barber). If you think Hotel California or BMW is better without XTC then you have not set it correctly.
