mmuetst
- Joined
- Mar 16, 2021
- Messages
- 102
- Likes
- 87
I am experimenting with the BACCH plugin for Windows. Now I use Foobar2000 software but notice that the plugin and also the linking of Tidal do not work very well. Now I want to try another program that also supports VST3 plugins: Element (software from Kushview). Now my question: How can you link with Element by using VB-Audio virtual cable and Tidal App. Under Foobar2000 I have added the Recorder (Foo-record) where I can select the Virtual audio output and in Tidal the Virtual audio input.
I am looking for a simple link without extra mixers or other applications, only linking the audio with the Tidal app.
So far Google has not given me a solution. Maybe here are some smart forum members with an answer/solution?
Extra info, I use a Komplete audio one external DAC (USB) with ASIO drivers to send the sound analog to my set. In Element you can only select one audio device.
